12-31-2022, 04:49 PM | #1 |
Rep 239
Ground grip
Good day dear Mates.
I need a important suggestion. My f83 is heavy tuned working perfectly stage 3/4 kratos turbo, eVenturi Intake, carillo pistons and arrow rods, Akrapovic DP, HCP Software, no opf, dorch pump, m5 injectors ... and other Now problem is also in 3rd gear while pushing gas the car ... lift up...no fron grip. Any suggestion to solve? Spoiler? Springs? Thanks for suggestion.
BMW M4 F83 Stage 3/4 - Akrapovic Skat DP, NO OPF, eVenturi Intake, Okada Coils, Kratos Turbos EVO, Dodson 1000 Nm Clutch Dct - Mishimoto IC, Water and Oil Coolers - CP Carillo Pistons - Arrow Connecting Rods - Reinforced bearings - Halim Cazimi HCP Software 2.0 bar Turbo - XHPFlashTool for DCT Stage 3+
12-31-2022, 05:07 PM | #2 | |
Rep 23
12-31-2022, 05:47 PM | #4 |
Rep 23
12-31-2022, 06:19 PM | #6 |
Rep 23
01-01-2023, 08:33 AM | #7 |
Rep 239
Smaller wheels should increase the torque on the wheel and would get even worse on my humble point of view but I might be wrong. Thanks in the meantime
01-01-2023, 09:00 AM | #8 |
Rep 196
As an F83 owner i don't understand why choose to so heavily tune an F83 that is about 450 pounds heavier than an F82...
Humdizzle6115.50 G35POPPEDMYCHERRY4998.50 |
01-01-2023, 09:57 AM | #9 |
Rep 239
That is the reason in fact. I m crazy for the performance. I m not going to challenge an f82, simply try to get the best from mine
01-02-2023, 02:56 PM | #11 |
Rep 239
Exactly, drastically, dangerous. Suspension standard f83 set to sport +, the other are worse. Tires at the moment hankook 19 winter. Summer time toyo r888r
01-02-2023, 06:48 PM | #12 | |
2039
Rep 2,680
What suspension, wheels and tires do you have? Have you checked alignment? Tire pressures? Something doesn't add up … |
jmg18846.50 |
01-02-2023, 08:01 PM | #13 |
6116
Rep 3,645
sounds like he's losing front end grip when flooring it. which makes sense. the f83 is very heavy. and with the top down there is more weight on the rear. then with big power you are throwing even more weight to the rear under acceleration. same problem that plagued older 911s with the front end going light
all i can say is just stick to straight lines. or send the car to a performance suspension shop to stiffen up the rear, add rake, and corner balance.
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
behindthen0thing839.50 |
01-03-2023, 07:46 AM | #14 | |
Rep 239
01-03-2023, 07:53 AM | #15 |
4999
Rep 4,139
tire pressure off by 1-2 psi in the front causing positive climb
01-04-2023, 03:55 AM | #16 | |
18847
Rep 14,138
Drives: G82 M4C X-Drive
If the rear is wiggling: You can tame the rear with negative camber, slight toe in, and a little forward rake. A performance oriented alignment shop can help you dial that in. You should also look into stiffer suspension and the widest tires you can fit for the rear, with adequate sidewall for grip. I’d also look into something other than Toyo R888’s. They are fine tires, but kind of the “popular” tire that gets marketed well, but there are better options out there. They are the Bose speaker of tires. Little control of the front: That’s kind of natural. All your weight is going to the rear. Your front wheels can help you keep straight, but not really change direction much under acceleration. Maximize stability with the stuff I mentioned above. If you are going fast enough, front and rear aero might help.
01-07-2023, 03:37 PM | #17 | |
Rep 239
Message rcvd with thanks |
