11-27-2022, 05:35 PM | #1 |
Rep 145
Drives: 2019 BMW X5 40i xdrive
F80 vibrations
Hi all, I need your help. I have a 2016 f80 comp and got some vibrations going on. Here's my situation:
- had no vibrations before mods - installed spacers front and rear, no vibrations - installed lowering springs, without spacers, no vibrations - installed spacers with lowering springs, vibrations. The vibrations start around 75mph. Spacers are installed correct. Anyone any ideas? Thanks!
F84 M4
2015 AA midpipe MPE carbon tips BM3 stage 1 |
11-27-2022, 06:08 PM | #3 | |
Boner
89
Rep 249
M4Dutch36.00 |
11-27-2022, 06:43 PM | #4 | ||
Rep 145
I did not do a alignment, think that would be necessary?
F84 M4
11-27-2022, 06:56 PM | #6 | |
Rep 145
Thanks all!
F84 M4
HotRodM4688.50 |
11-28-2022, 02:04 PM | #9 |
Rep 145
I just called Shoreline Motoring, they don't think its alignment.
Factory 666 wheels, spacers are hub centric. I had no issues with just spacers (no lowering springs), and also no issues with just lowering springs (no spacers). The combination of lowering springs with spacers gives the vibrations….. This drives me nuts.
F84 M4
11-28-2022, 06:53 PM | #12 |
Rep 145
If I take the spacers off, the problem is solved. But when I had the spacers on before installing the lowering springs I also had no issues….
F84 M4
11-28-2022, 07:07 PM | #13 |
Rep 171
Drives: 2015 BMW M3
It certainly doesn't sound like alignment if the vibration is only there when the spacers are installed. Even a bad alignment, doesn't cause vibration. Bad alignment would cause the tires to "chop" and after a few thousand miles, voila, vibration.
Be sure to check all clearances behind the spacers. Ensure there's no perforating metal debris. Ensure all bolts (rotor screws and spacer if spacer has securing bolts equipped) are flush correctly. The problem is either debris between spacers, OR a badly warped spacer, not letting the wheel seat correctly. This honestly sounds to be more of a wheel seating issue than anything else. |
M4Dutch36.00 |
11-28-2022, 07:12 PM | #14 |
Rep 145
Appreciate your reply. I cleaned everything, on the wheel hub and the spacers. Dont think it can be any debris.
The only option I can think of is a warped spacer, although when I seat the spacers I didnt feel any movement. I might make the trip to EAS tomorrow to have it checked out, or get new spacers. I am now used to the looks of this setup so dont want to go back to no spacers.
F84 M4
