11-13-2022, 10:43 AM | #1 |
Rep 229
Drives: E90 M3
Fuel Injector Replacement Questions
One fuel injector is leaky—misfires in one cylinder on cold start, pulled plug smells like ethanol (E85), and swap coils misfire did not follow.
Gonna get all new injectors cause why not, takes out guess work. I saw I will need to code the new ones. Couple questions just to mentally prepare. (1) The values of the injectors are on the injectors. Correct? (2) It looks coding can be done with Protools. Correct? Any input is appreciated. Thank you
yt:itoto
insta:@m3.toto |
11-13-2022, 11:43 AM | #2 |
Rep 703
I don't believe the S65 injectors require any coding after replacement (perhaps unless you're replacing with a different size injector, but I thought that would be handled by a custom tune?).
I replaced my injectors and did not do any coding. |
itoto115.50 |
11-13-2022, 12:46 PM | #4 |
Rep 229
Drives: E90 M3
Thank you. I will look in it, although I am afraid too
yt:itoto
insta:@m3.toto |
11-13-2022, 07:12 PM | #5 |
Rep 229
Drives: E90 M3
Did you bleed the system afterwards? I just finished taking off the injectors and prepping for the incoming ones. You got the bosch ones correct?
yt:itoto
insta:@m3.toto |
