11-05-2008, 05:46 PM | #1 |
140
Rep 1,597
Drives: MY2022 X5 M-Sport 45e White
Do Vert Springs have diff part No. to the Coupe
Can someone answer this question.
Because the Vert is some 250kg heavier than the coupe are the springs difference in both front and rear or just the rear only?
MY22 X5 M-Sport 45e White, 22"rims, Red Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, otherwise all option boxes are ticked. |
11-05-2008, 08:59 PM | #3 |
140
Rep 1,597
Do you know if Eibach has two different part numbers as well?
I checked there site but as far I could see the only list one.
11-06-2008, 02:02 AM | #4 |
140
Rep 1,597
Ok I found the Eibach springs for the vert, just released, the part number is 20101.140. The drop for the front is 1" and the rear is .6.
The springs for the coupe which have been out for a while are part number20100.140, front drops .8" and the rear drops .6". Interesting they are now droping the front by 1" on the vert, the vert must sit a little higher to start off with!
11-06-2008, 02:21 AM | #5 |
140
Rep 1,597
Hi Fellas, could someone there State Side call Eibach and ask them why they are dropping the vert by 1"? whereas the Coupe is only dropping .8"
Thanks
11-06-2008, 12:27 PM | #6 |
3571
Rep 9,788
I believe the vert sits a bit higher than the coupe so when you drop the car, it will give you a lower drop. However, in the end, both should end up at about the same ride height. The same thing is true about sport and non-sport suspension equipped vehicles.
