M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      12-29-2020, 11:32 AM   #1
prelude2perfect
prelude2perfect's Avatar
60
Drives: 2013 M5 and 2015 535i
Federal Evoluzion F60 Tire Review
It's been a couple thousand miles since I put these on my 2013 M5 (stage 2 93 oct BM3 tune), and I really wanted to share how much I like these tires.
Backstory:
I purchased this car back in October and the previous owner had recently installed a brand new set of Michelin Pilot Super Sports. Those tires, as most know, are not very good a putting high power to the ground. 1st and 2nd gear were about useless, and unless they were up to temp, 3rd gear would easily break loose as well. After about 4 thousand miles of use, I started to lose air in my front left tire. I jacked it up expecting to find a screw or a nail, but instead found the inside of every tire worn to the cord. Previous owner says it was aligned after the Dinan suspension install, but if so, they must have done a horrible job.
Coming previously from a 600hp 335i and running the Federal RSRR tires (another amazing tire for the price) I started to look to see if I could find them in the right size for this car, but unfortunately they don't make them in anything bigger than an 18. I did however come across their new tire, the Evoluzion F60 which is aimed at cars like these. Unfortunately there were almost no good reviews online, but because of the price point, my experience with their RSRRs, and the fact that they won the Red Dot award for this tire as well, I decided to take a gamble. Man I'm glad I did.
These tires are much stickier than the PSS's and handle corners just as well too. I can now get almost all my power down in second gear once I get the tires up to temp, and first gear is much more manageable. Too early to rate tire wear, but I'll report back when I finally wear them out. I expected road noise to be bad since the RSRRs were very loud tires, but I'm happy to say these are very quiet tires. I cannot compare them to the PS4s as I haven't tried them yet, but I would guess that they are probably very close, if not on par with them.
These tires are a far better choice than the much more expensive PSS, and well worth heavy consideration if you're thinking of the PS4s.
Fast.F10513.50
      01-02-2021, 01:50 AM   #2
aliusa
aliusa's Avatar
Drives: F10 M5 CP
Backstory:
Good to know and thanks for sharing your thoughts. Never heard of this tire before. Mind sharing some pics to show how they look on the //M?
      01-05-2021, 05:57 AM   #3
prelude2perfect
60
Added them to original post
aliusa86.00
      01-05-2021, 07:37 AM   #4
Fast.F10
Extruding Elements
Fast.F10's Avatar
Drives: 2016 BMW M5 Comp
2016 BMW M5 F10  [0.00]
How sticky are they when in M2 (spirited) mode? Any rain use thus far?
2022 Yukon XL AT4
2016 BMW M5
2015 Ford F250 Super Duty
2006 BMW M5
      01-05-2021, 09:38 AM   #5
prelude2perfect
60
My review was based off the car being in M2 with traction control completely disabled.
Minimal rain use, but I took a few hard corners in the heavy rain and it felt great.
Fast.F10513.50
      01-05-2021, 10:21 AM   #6
Fast.F10
Extruding Elements
Fast.F10's Avatar
Since I assume you sourced the best price shipped...mind sharing where you purchased?
2022 Yukon XL AT4
2016 BMW M5
2006 BMW M5
      01-05-2021, 11:28 AM   #7
prelude2perfect
60
They were difficult to find for sure. I had to buy the fronts from Simple Tire and the rear from amazon. Looks like the rears are currently out of stock from where I purchased from on amazon. I would give simple tire a try and see if they have them in stock again.
Fast.F10513.50
      01-05-2021, 01:39 PM   #8
Fast.F10
Extruding Elements
Fast.F10's Avatar
From Simple: We are unable to predict if at all when these tires will be back in stock. :unicorn:
Cant find these jokers anywhere...wonder if that is a sign?
2022 Yukon XL AT4
2016 BMW M5
2006 BMW M5
      01-05-2021, 02:48 PM   #9
prelude2perfect
60
That's too bad. If it was me, and when these tires eventually need to be replaced it will be me, I would reach out to Federal directly and ask them for a good distributer.
      01-05-2021, 03:40 PM   #10
prelude2perfect
60
Here’s a little video I took to show the straight line traction for some second gear pulls:
Fast.F10513.50
co_pa223.00
      01-05-2021, 03:53 PM   #11
Fast.F10
Extruding Elements
Fast.F10's Avatar
Nice 335i
2022 Yukon XL AT4
2016 BMW M5
2006 BMW M5
      01-05-2021, 03:55 PM   #12
Fast.F10
Extruding Elements
Fast.F10's Avatar
Send an email to them as well as other companies I noted that sold Federal....we shall see.
2022 Yukon XL AT4
2016 BMW M5
2006 BMW M5
      01-05-2021, 10:24 PM   #13
HXS
Licensed Drug Dealer
HXS's Avatar
Drives: F10 M5
OP, are those 295's or 305's out back in the M5?
      01-06-2021, 08:00 AM   #14
prelude2perfect
60
Nice. Let us know if you get any responses.
      01-06-2021, 08:02 AM   #15
prelude2perfect
60
305/30/20 out back
265/35/20 up front
HXS743.00
      01-06-2021, 08:03 AM   #16
prelude2perfect
60
Nice 335i
Thanks. Sold it to get the M5. Was a great platform I will certainly miss
      01-06-2021, 03:53 PM   #17
Fast.F10
Extruding Elements
Fast.F10's Avatar
Think Im going to head back to the MPS4 route. Was able to find the 305 30-20 on ebay but the 265 35-20 are NO WHERE to be found. Thanks for this post and prompt replies.
2022 Yukon XL AT4
2016 BMW M5
2006 BMW M5
      01-07-2021, 12:39 PM   #18
prelude2perfect
60
No problem at all
m5post
