08-21-2020, 04:32 PM | #1 |
Rep 1,206
How not to preload the front saw bar End links
Should the front suspension be at rest on the ground before you torque the sway bar? It seems like people make a big fuss about torquing the rear on the ground but not the front.
08-21-2020, 06:41 PM | #2 |
591
Rep 469
08-21-2020, 08:33 PM | #3 |
Rep 1,206
08-22-2020, 10:44 AM | #5 | |
591
Rep 469
08-27-2020, 03:56 PM | #8 |
Rep 1,191
Is you have stock suspension it doesn't matter. If you have adjustable height suspension (HAS or C/O's) then it's possible for the bar to be preloaded If the left and right side are not set to exactly the same ride height. If the left/right ride heights are the same there's no issue.
If you need to set different ride heights to corner balance the car, you can get adjustable links to account for the slight height difference and keep the bar unloaded.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
