07-28-2020, 09:02 AM | #1 |
Rep 106
kW HAS kit vs KW V3 on a 2015 CP
Hi
I know that this dilemma have been brought up before, but I simply can figure out what to go after. Having a CP makes the decision even harder. I have narrowed down as I see it what the benefits and cons are for each path, please feel free to help me make the right decision, KW HAS benefits:
KW HAS downsides:
KW V3 BENEFITS:
KW V3 downsides:
What would you do ? |
07-31-2020, 08:15 PM | #2 |
Rep 57
KW HAS!
i have a cp as well and that is current setup. With K.W HAS your steering wheel feels a bit stiffer as compared to the stock set up on the stock 343 rims. I run cup 2 .. 265 fronts and 305 rears... they filled out the gaps pretty nicely.
TinTin
The Dane111.50 |
08-01-2020, 01:24 PM | #3 |
Rep 106
I ordered the the Kw has setup, mps4s in r305- f265, and 10mm spacers for the front only to compensate for the wider tires in the back,
Oh I also order a set of 601m competition wheels, I have a feeling that it's going to look epic 😎 |
06-30-2023, 01:32 PM | #4 | |
Rep 92
what was ur alighment specs for the front camber after u got it aligned. i know there is no adjusment in the front for camber |
