06-03-2020, 05:26 PM | #1 |
Rep 33
Considering buying a 2015 M4 with 65k miles. Thoughts?
Hey guys,
looking into picking up a 2015 M4 with 65k miles. The carfax is clean and shows regular maintenance thus far. The brake pads/rotors have not been changed yet. The car has already been through 3 owners and the most recent owner has only put 7k miles on the car in the last two years. The car has been sitting in his garage for the most part over the last 6 months. He said the battery drained once but is now up and running again. I will be getting a PPI at EP3 Motorsports out in St. Charles IL. I wanted to get some of your thoughts. 1) Is the car worth 28k? 2) Has anyone reached high mileage and run into issues with their F80 or F82? 3) Do any of you have third party extended warranties? Thanks in advance! |
06-03-2020, 05:34 PM | #2 |
Rep 5
Whoa that's a really great price. I picked up a 2016 M3 just 6 months ago for like $12k more with 58k miles. I knew it wasn't a great deal, but I really wanted the car. I think Covid really blasted the used market in favor of buyers.
If the PPI shows everything is good, I would jump on it. Just make sure the PPI is super thorough. Just because the Carfax is clean doesn't mean nothing has happened to the car, just that any work that may have been done wasn't reported through insurance. I have a third party extended warranty, haven't had to use it yet. Hopefully if it comes time to use it, they'll actually pay out. I've heard mostly negative things about 3rd party warranties, but I guess we'll see. Good luck! Edit: If this M4 has the carbon ceramic brakes (M4 competition models), you're looking at $18k-20k to replace the pads and rotors with OEM parts. If it's not a competition and has the normal brakes, it'll still be around $1300 to replace them. That may be why it's priced so low. Last edited by Carrera16M3; 06-03-2020 at 05:41 PM.. |
06-03-2020, 05:38 PM | #4 | |
779
Rep 1,636
Also, the convertibles are worth less so if this is a coupe not vert, it's an even better deal. Check KBB value. 2) I just bought a used f82 so I did a lot of research on this as well. I've basically come to the conclusion that if maintained properly, not beaten on/tracked and if you're on the stock tune you should not have any issues. 3) Buying a warranty on an M4 with 65k miles would be expensive asf. I was getting 4k-6k sh quotes from fidelity/easycare on a 2016 with 32k miles. Also, those are pretty much the best warranty companies as most are suspect. USAA is good but you need to be military. I'd consider buying a used M4 with high miles from carmax, they have a few and their warranties are really affordable considering they're reputable, bumper to bumper as well as available on high mileage german cars for not too much money. |
06-03-2020, 05:39 PM | #5 |
Rep 168
Drives: G82 M4, F98 X4M, F82 m4 - sold
Seems like a very solid price point. Based on what I've seen, if these cars are maintained regularly they will last a very long time. Engine is pretty reliable!
06-03-2020, 05:41 PM | #6 |
Rep 33
06-03-2020, 05:43 PM | #7 | |
Rep 33
Brakes are non ceramic and hoping the PPI will tell me if they will need to be replaced soon. |
06-03-2020, 05:49 PM | #8 | |
Rep 33
Carfax shows 5 oil changes at dealerships and current owner claims to have done an oil change and brake fluid himself recently. Was considering running a BM3 Stage 1 tune. I've tried calling one company so far and they said California wouldn't even allow them to cover an M4 haha. I'm going to try calling a few more. Carmax has some but they're price in the mid-30s. Hope you're liking you're F82! |
06-03-2020, 07:19 PM | #9 |
Rep 33
Hope that's the case with this one. Will have to meet up with you in the bay at some point either way haha
06-03-2020, 07:21 PM | #10 | |
Rep 168
06-03-2020, 08:18 PM | #12 |
4269
Rep 1,625
06-03-2020, 08:39 PM | #13 | |
Rep 33
06-03-2020, 09:26 PM | #14 | |
779
Rep 1,636
Also note that car should be on it's third set of spark plugs, first change at 30 and next change at 60. If not, change them ASAP. I'd do a CBC for a few hundred or even the full crank hub for 1500 ish if you're driving a tuned M4 to be safe from the crank hub spinning. |
06-03-2020, 09:31 PM | #15 | |
In The Rain
8210
Rep 6,273
Drives: '24 GT4RS, '24 Macan GTS
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" |
06-04-2020, 01:48 AM | #16 | |
Rep 5
06-04-2020, 06:37 AM | #17 |
901
Rep 3,071
Get Carly app and wifi obd2 connector to do a scan
The car has service info which tells you when brakes are due. No substitute for inspection but if sensors say overdue or no miles left then plan for replacement (and probably rotors too). Battery damaged and 6 years old, they last 7 years or so and are very expensive to replace Yes spark plugs long overdue
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
06-04-2020, 07:53 AM | #18 |
1797
Rep 2,997
I just sold my 2015 m3 with 71k miles for $32k. Stripper model with 6mt, very similar spec to that.
Mine was one-owner (me), never tuned, in great physical/mechanical condition, with full maintenance records and no stories or immediate needs. I probably got a premium price because of condition and rarity of finding that spec (very low weight 6mt sedan). Is that one worth $28k? Yes, I believe so. HOWEVER, there's a few question marks on it so get your PPI and plan on putting $2k into it to get it ready for daily driver status.
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
06-04-2020, 03:13 PM | #19 | |
Rep 33
