05-24-2020, 05:22 PM | #1 |
276
Rep 417
Review: MSS springs with B6 EDC dampers
Anyone feel free to chime in here, but apart from Imran from Evolve, I believe I'm one of the few around running this set-up.
Backstory: Getting the MSS springs to work with the B6 dampers was a royal pain as the adjusters that came with the kit wouldn't work with the B6 dampers. It was finally solved in the end thankfully as MSS sent new adjusters as they have modified the kit a bit and the adjusters now sit at the top of the strut instead of the bottom. How they feel: I'm very happy with the results. The car feels solid, has good turn in and less body roll. It has a slightly firmer ride than stock but it is very compliant and doesn't feel as firm as coilovers. I feel as if the car can put its power down a bit better but overall just the way it has made the car feel to me is what has pleased me the most. Comfort mode: Slightly firmer than stock but compliant Sport: Firmer than stock Sport +: With the stock set-up, as everyone else laments, it feels a bit floaty and crashy. That has gone. The only gripe I have, is I wish that the front end was a bit lower but I guess I will have to live with it. The rear is perfect. Here's an image of how my car sits:
F82 M4 | 6-speed manual | PP performance Stage 2 tune | Re-valved Bilstein B16s | VRSF midpipe | OEM CS front splitter | OEM GTS hood | OEM M-performance rear diffuser| Evolve tuning catless downpipes | 310rwkw (415rwhp)
05-24-2020, 08:07 PM | #3 |
2892
Rep 2,147
KW HAS doesn't fit B6D shocks so MSS is the only option for height adjustable springs.
YT: ntg44
05-25-2020, 01:42 AM | #6 | |||
276
Rep 417
They state 0-30mm, but I'm not so sure.. Quote:
05-25-2020, 06:57 PM | #8 | |
276
Rep 417
That M3 looks slightly lower than mine in the front, but it's hard to tell as it looks like they're also running a higher profile tyre. I'd like to come down in the front another 10-15mm, but not sure if I am going to achieve that with the MSS springs unless they offer more adjustment or a shorter spring. But, function over form in this case as the car drives really well.
RoadRunner///M463.50 lavon2.00 |
