      04-18-2020, 12:30 AM   #1
Marcus.Y
Drives: BMW E82 135i
10mm Spacer
Hi Guys,
I am thinking of putting in a 10-12mm spacer to my 135i wheels (215 front and 245 back) to make the tyres flush to the car and for a more aggressive stance. Just wondering what is the general consensus regarding this and if there are any pro/cons and if it is even worth the money.
Thanks in advance.
      04-25-2020, 08:52 AM   #2
juld0zer
Australia
480
Drives: Prev 135i 7DCT, Now 130i 6sp
Make sure the spacer actually fits over the hub lip on the rear.
You can measure it with a ruler but every manufacturer is different in how they bore out the centre of the spacer. eg. 10mm hub lip protrusion may still foul the inside of the spacer.
I had to grind my hubs down a bit. Still heaps of meat left as the rim only touches a 5mm wide area
      04-26-2020, 08:10 PM   #3
dainese
Drives: BMW 135i
I was able to fit a 15mm spacer to my rears for a flush look. on 245/35 PS4 tyres.
Fronts were also 8.5" wide on a 225/40 and I had a 12.5mm spacer
https://www.turnermotorsport.com/t-wheel_guide
there is also a guide on using spacers less than 10mm
      04-27-2020, 03:33 AM   #4
woosh
woosh's Avatar
Australia
214
Drives: rs
The usual go-to spacers for street work: https://burgertuning.com/products/e-...heel-spacers-1
A set comes up for sale in Australia every few months. I've ran them on multiple cars, mainly for the looks.
      05-03-2020, 04:16 AM   #5
thezone135i
thezone135i's Avatar
Australia
54
Drives: Volvo S60 R-Design Polestar
2008 BMW 135i  [0.00]
2012 BMW 535i  [0.00]
I had 10mm front 12mm rear on my 135i and I found it improved the handling quite substantially. No need to get Burger, there's a mob called Caold technology in Clayton Vic, which engineers them, I've had three sets of hub centric ones for them and they have all been spot on. You can buy them on ebay, and if they don't list them you just message them and the will custom make the size you need.
1addicts
