04-04-2020, 02:38 PM | #1 |
1099
Rep 2,286
Any difference Pagid RS29 vs RSL29?
I'm seeing conflicting information on this - I assume that even if there is a difference - that it is minimal - and both pads perform almost the same.
However - anyone who can shed light on any differences would be appreciated, |
04-06-2020, 04:18 AM | #2 |
21131
Rep 20,742
Drives: 2021 911 turbo
I am not sure if it is just a re-branding or if Pagid actually did something to the compound/construction. One thing though, is that since Pagid changed the name, I've had three instances of the pad shearing off the backing plate with about 4~6mm left of the pad. Maybe it is just a coincidence and it has nothing to do with the name change, but it's not a fun experience when it happens and I am switching to PF08 this season.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
04-06-2020, 04:29 PM | #3 | |
1099
Rep 2,286
04-06-2020, 06:20 PM | #4 | ||
1099
Rep 2,286
04-18-2020, 10:57 AM | #5 | |
362
Rep 518
04-18-2020, 12:26 PM | #6 | |
21131
Rep 20,742
The stock irons have worked perfectly fine for me thus far.
04-19-2020, 01:07 PM | #7 | |
362
Rep 518
You're obviously pretty fast and pushing the limits and the chances are, you're reaching the limit of the stock brakes. The rotors are heavy, but I can't see BMW fitting them to the M2 to slow it down or devising the kit if stock brakes are ideally efficient. 19's aren't ideal or cost effective I agree. |
04-19-2020, 01:21 PM | #8 | |
21131
Rep 20,742
The stock irons provide me sufficient braking power for my driving style and the track I frequent, hence why I don't feel the need to upgrade. If I were to upgrade though, I would go for a proper BBK, these M2 brakes are way too heavy.
04-20-2020, 09:27 AM | #9 | |
362
Rep 518
The pads with this particular car and brake setup was a heat dissipation issue from the car being under-braked. The M2C brakes will definitely dissipate heat better than the stock brakes, but the weight's in the rotors that could be lightened significantly with an aftermarket variant. They were surprisingly cheap in Australia, just over 6k and 5k cheaper than anything better and a genuine BMW kit's worth a try. |
04-22-2020, 04:18 PM | #10 | |
336
Rep 591
I did try them again at the Chin Feb event and outside of the white ash and losing all the paint color, they looked like they'd barely been used(like has happened the last 3 years with these pads). Almost makes me wonder if they sent the wrong pads for that event in August |
06-25-2020, 04:47 PM | #11 |
Supreme Allied Commander
3888
Rep 54,534
Drives: F80 M3
They are the same. RS29 is the current name for that pad. Some pads are still shipping in the old boxes and showing RS29 but some are shipping under the new packaging with RSL29 on it.
06-28-2020, 06:00 AM | #12 |
21131
Rep 20,742
Wow, just did my first event with PF08 on my F82, what a difference. The braking is so much more confidence inspiring and they barely showed any sign of wear. That's how I remember the RS29 being. PF08 it is as of now, I won't be going back to RSL29
MPoweRo428.00 |
06-28-2020, 01:17 PM | #13 | |
1099
Rep 2,286
CanAutM321130.50 |
