03-13-2020, 05:07 PM | #1 |
131
Rep 485
Firmware/software update is not FREE
I have a 2018 M3 and it is still under full warranty and full-service agreement.
Made an appointment to get firmware/software update and the SA told me that it is not free and that I had to pay $300 to do that. Is this true?
2015 M235i xDrive 8AT
03-13-2020, 05:23 PM | #2 | |
8267
Rep 18,854
Drives: BMW
If you can prove something is malfunctioning in which the update would correct (iDrive resetting, Bluetooth calls dropping, etc), it would most likely be covered.
03-13-2020, 05:52 PM | #3 |
2913
Rep 2,782
Drives: 2020 M4 ZCP / 2023 X3 M40i
You need to describe a problem that would be fixed with a ISTEP update for it to be free.
03-13-2020, 06:02 PM | #4 |
131
Rep 485
In this day & age, such an operation should be done from the car via the cell connection without a mechanic, let alone charging for it.
Ludicrous policy. What made it ridiculous was they should have told me this over the phone when I made an appointment, not after I driven all the way to the dealership.
GKay28.50 |
03-13-2020, 06:03 PM | #5 |
8267
Rep 18,854
Drives: BMW
What are you hoping to gain by a software update?
PhatLyfe985.00 |
03-14-2020, 06:01 PM | #7 |
131
Rep 485
If there is firmware update, it means there was something which BMW has found that needs to be corrected or improved on.
That's why there's a firmware update.
03-14-2020, 06:29 PM | #8 | |
8267
Rep 18,854
Drives: BMW
Newer doesn't necessarily mean better in all cases. If you're that concerned, pay the money and get it updated.
03-15-2020, 12:55 AM | #9 | |
4495
Rep 10,473
You expect that for free as well? If updates were always free, you’d get map updates free for life. |
03-15-2020, 02:48 AM | #10 |
Rep 71
From a business perspective someone needs to pay the technician labor time to update the vehicle. This usually takes a while depending on the control unit which takes up a lift when a tech can be doing a service. Bmw warranty covers manufacturers defects if you just want the software updated for the hell of it bmw will not pay the tech warranty time to do it and of the dealer does it free they are losing revenue so it has to come from somewhere hence it being 300$. The part that doesn't make much sense to me is why its 300. Usually its an hour labor to update a vehicle and I don't think the labor rate is 300/hr
03-15-2020, 09:58 AM | #11 |
The G8X is a disaster. 🤮
931
Rep 988
03-15-2020, 04:31 PM | #12 |
2545
Rep 3,968
From what I have read, this is not a 2 minute thing AND things can go wrong - causing the car to be there for a while - since BMW has to get involved.
WORSE, lots of stuff can change that you didn't want to change. For instance, I believe the latest software* makes it impossible to turn off rev match - that would tick me off! *late 2018 M3 builds lost this ability, so just a guess.
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual 2023 X3 M40i - loaded sans Park Assist |
03-15-2020, 05:37 PM | #13 |
Rep 1,239
New software
I got a new software through warranty last year. Mine is a yr 16. Is it true that the new software makes shifting (DCT) less jerky? Common for yr 15 and 16? Frankly, I can't tell the difference. I didn't even have to ask for it. Downside, wiped out my Amber delete, fancy door chime, fuel all the way down less than a fourth tank before it lights up, brighter headlights etc,etc.
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
wlin0010.00 |
03-16-2020, 10:39 AM | #14 | |
1397
Rep 3,152
Step 2: Complain about bluetooth dropping Step 3: Enjoy you free new programming Step 4: You're welcome
