02-08-2020, 12:23 PM | #1 |
Rep 1
2017 X5 3.5d maintenance.
Hope all is good.
My lease on my 2017 X5 3.5d is about up and I’m thinking about buying it out. Any thoughts on the cost of maintaining a diesel, I’ve heard that new restrictions have made them really expensive. Thanks in advance! |
02-08-2020, 01:44 PM | #2 | |
Rep 121
- Obvious.. changing oil/filter, air filter, coolant etc regularly. Adding DEF, changing fuel filter every 20-30k miles. - If you do more city driving, take it at least once a week on a highway for a longer period of time to let DPF to regenerate and burn the soot and you should be fine. Maybe I'm missing something...other members could pitch in |
02-09-2020, 10:37 AM | #3 |
Rep 1,270
DPF regeneration takes place at any speed on any road. While it is true that is more effective at speeds above 40mph, driving on a highway to do this is only a myth.
02-09-2020, 06:20 PM | #4 | |
[Oo=||=oO]
1105
Rep 2,470
The big question is: who will be doing the maintenance? You? Dealership? Indy? Oil changes cost a bit more because of DEF refills. However, everything else is the same as with gas variants. With D, you don't have to worry about plugs, or coils. Just change fuel filter on regular basis. Cost of maintenance is bit higher than Honda or Toyota, due to frequency of required maintenance. For example: brake flush every two years, coolant flush every two years, dif oil changes, oil changes every 10k miles, etc. However, even Honda and Toyota are getting close to maintenance requirements as BMW since they started going with direct injection turbo engines. |
02-11-2020, 12:50 AM | #5 |
Rep 1,151
Drives: 2022 x5 40!
Regen
Do u ever here your car doing a regen i used to be able to smell it but not after the egr vale and cooler got replaced . On my Vw i can tell all the time rpm go up and smell and exhaust sound like a slight burble . I could not tell u the last time my x5 35d has done one. Just thinking maybe it only does a regen on the highway ? Dealer says its working
02-11-2020, 04:29 PM | #7 |
Rep 1,487
I'm pretty sure BMW still hasn't solved the CBU (carbon build up) issue with the diesel's, hence the reason they are no longer offered in North America. That's the only reason I didn't buy mine out after the lease was up. Here in Illinois we get terrible quality BioDiesel that wreaks all kinds of havoc on the emissions equipment.
Blessed Beyond Measure
02-12-2020, 09:42 AM | #8 | |
Rep 366
We have about 85,000 on ours now. Had the recall done on it, and if it ever gets to the point where it needs emissions equipment replaced. Its going in the dumpster... The emissions.
2014 X5 35d X-drive. Space Gray Metallic. Mocha Dakota Leather.
Al Pină1839.50 |
02-12-2020, 09:47 AM | #9 | ||
Rep 1,487
02-12-2020, 09:56 AM | #10 | |
Rep 366
We do a lot of short trips, usually a 20 mile jaunt each way during the week. But, at times, usually a few times a month, we go out and rip on it lol
02-12-2020, 10:09 AM | #11 |
Rep 1,168
Diesels are not inheritently dirty; it's the emissions bolt-ons such as EGR that cause the bulk of CBU issues, further affected by quality of fuel used, driving patterns, condition of other components and other factors that may be within or not of your control.
The maintenance itself isn't much different - $$ wise,- than gazzers. But there are just more components that may break/require attention. |
02-12-2020, 03:15 PM | #12 |
Rep 366
Wipe your finger on a non-emissions diesel exhaust pipe. Bet your finger turns black. lol The whole back corner of my truck is black.... Diesel fuel being burnt creates soot, no matter how good of the fuel, or how you drive. It only increases or decreases how much it makes. Route that back into an intake (EGR), and naturally you get build up. I didn't say the diesel engine makes the intake dirty. The emissions are the issue. Routing dirty exhaust back into the intake. Ive been working on diesel vehicles for 15 years. Trust me, I know how they work lol
When you replace a catalytic converter on a gasoline vehicle, you're talking a few hundred. Replacing a DPF or Catalytic converter on a diesel, you're talking a few thousand for it all. EGR has been around for decades on gasoline engines. They generally don't cause issues. EGR's on diesels have been causing issues since day one. Add in the catalysts and their components and holy crap is it bad. Had a pump burn up on a piece of equipment... $4,700 to replace the pump. Thats not including labor. Its all a racket.
Al Pină1839.50 |
