01-03-2020, 02:00 PM | #1 |
Rep 147
Exhaust Tip Qusetion
I have a 35i, non-M exhaust. Want to switch out the small round tail pipe covers with some new larger slip-ons. Seems that some people use 2.5 inch and some say 3 inch. Ebay says 2.5 inch is compatible.
So it looks like the actual size is somewhere in between. Will the 2.5 work??? Thanks Last edited by Jason73; 01-03-2020 at 03:12 PM.. |
01-03-2020, 04:21 PM | #3 |
Rep 1,247
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
Ours are welded on - you know that right?
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
01-03-2020, 05:06 PM | #5 |
185
Rep 538
Really? Can you share a pic? If the tips are off I would expect you could get some aftermarket ones on there pretty easily. With the stock 35i tips (non msport) there is a flare at the end making it difficult to slide new tips on.
01-03-2020, 05:41 PM | #6 |
Rep 147
Once I figure out which ones to order I will. I put the factory one back on once I figured out they weren’t welded on.
Just need to know what to order 2.5 or 3.0 inlet size. I am definitely going with 3.5 for the outlet. Last edited by Jason73; 01-04-2020 at 05:58 AM.. |
01-03-2020, 08:15 PM | #7 |
Rep 1,354
Drives: 2022 X5 m50i
On my 2013 535, I removed the OEM tips and replaced them with 3.5" Magnaflow stainless steel ones.
No rust, no discoloration. They filled the stock opening and looked beefier and way better than the small stock ones. They were not slip on but two tack welds on each kept them sturdily in place. Later, when I returned the car, I took them of and welded back on the original ones. 5 minutes job.
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
201199.50 |
01-04-2020, 03:56 AM | #8 |
Rep 147
01-04-2020, 10:40 AM | #9 |
Rep 1,354
2.5"
2022 BMW X5 m50i
01-06-2020, 03:29 PM | #11 |
Rep 1,247
On a F15 35i?!?!?!? All of them I have ever seen have been welded on!
01-07-2020, 04:44 PM | #13 |
Rep 1,247
I'll be damned......I'll have to look at mine again.
When it get warmer of course...........
01-10-2020, 10:55 AM | #14 |
Rep 147
2.5 is too small. Need at least a 3 inch. Will be returning the 2.5 and have ordered a 80mm from AliExpress. Will know in a few weeks. Measured the exhaust pipe without the cover and it is a touch over 3 inches.
03-03-2020, 01:25 PM | #15 |
Rep 334
Drives: 991.2 C2S
Any update on this? Interested! Thanks
2025 LCI Skyscraper/Silverstone M4 6MT week 16 build status 193 at the port
2019 Black Sapphire/Coffee G05 X5 X50i MSport | Stock AF Grocery Getter 2013 Titan Silver BMW K1300S | Full Akro Exhaust Retired: F82 M4 6MT, F15 X5, F30 328i, E46 330Ci, E46 325Ci |
09-11-2020, 07:03 AM | #20 |
Rep 74
Here is an existing post with links, photos and information.
https://f15.bimmerpost.com/forums/sh...ght=round+tips |
