10-06-2019, 01:01 PM | #1 |
Rep 16
Brake fluid and other service items.
I am just about to cancel my dealership service as they want £1000 for an oil change, micro filter, front pads and brake fluid.
I know this might not seem like much but I cant get my head around £400 of the bill being the oild change when I can get the oil (Edge 0-W40) and genuine oil filter for £100 !? Anyway does anyone know what brake fluid would be best, I have been offered dot 5.1 by several retailers saying its the righgt stuff but I am looking at this Castrol React Performance Dot 4 Fully Synthetic Car Brake Fluid. Any help greatly appreciated. Also suggestions for front pads that are as good as OEM but not £400!? for front pads... |
10-06-2019, 01:41 PM | #2 | |
61727
Rep 19,942
Stick to dot 4 synthetic ,dot 5? might be good for track but maybe not for road. |
10-06-2019, 03:58 PM | #3 |
Rep 1,107
I'm sure you are going to get a ton of opinions but for me, I flushed mine with BMW brake fluid, nothing crazy. I do not track my car, fine for what I use the car for.
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
10-11-2019, 03:50 AM | #4 |
811
Rep 1,847
I would expect to pay £250 for an oil change and £70 for a brake fluid change at a fair main dealer. Pads are expensive but if you can find a dealer who will let you supply your own parts then you can buy parts from Alex at Cotswold BMW in Cheltenham
I paid £108 for oil and a filter and then £38 Labour to change it. I got discs and pads for the front for £800 In London you tend to get robbed |
10-11-2019, 09:10 AM | #5 | |
Rep 16
Taking it to a specialist in London on tuesday and £300 labour to change the lot. So £550 not the end of the world. I do this more these days as I've just seen so many dealers cutting corners and using close but not quite the right oils. Better for me to buy all the consumables and give them to the mechanic. |
10-11-2019, 12:12 PM | #6 | |
811
Rep 1,847
What made you get 0W-40? |
10-11-2019, 02:15 PM | #7 | ||
Rep 1,107
10-19-2019, 07:44 AM | #8 |
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
OP. It seems most of your questions have been answered or worked out but I'll add my 2 cents anyway.
Sounds like you're making a good decision by taking the car to an indy. Buy your own parts and have them install. Re: OIL - 0w-40 is indeed an optional factory approved weight. The theory is it's optional for climates where the 40w is better. Technically where I live should use 0w-30 but I've only run 0w-40 with no problems and in fact it burns less oil now. Re: BRAKE FLUID - I read somewhere that you want to use DOT 4 or better, and if possible the DOT 4LV, which stands for low viscosity. A lot of newer cars call for this because more systems are being run hydraulically than just the 4 corners of brake. I bought Pentosin DOT 4LV and flushed the system myself. |
10-19-2019, 12:19 PM | #9 | |
Rep 948
11-15-2019, 10:58 AM | #10 | |
61727
Rep 19,942
