07-07-2019, 05:03 PM | #1 |
Rep 7
Creaking/squeezing front suspension BMW M5 F10
Hello,
I have a pretty iritaring sound coming from mine front end on my M5 F10. Sound appear only when driving with low speed. For example i hear the noise on uneven roads when going slow, and i also hear it when i start roling from the trafficlight for example. Please see the vido i have uploaded. What could the problem be? I have read all about wheelbearing, dry bushes, sway bar and so on. What do you think guys? Hope somebody can help me out with this, it is so irritaring.. |
07-09-2019, 05:57 AM | #2 |
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
Sounds like a balljoint to me or possibly the strut. You weren't turning the wheel at all, correct?
07-09-2019, 06:15 PM | #3 |
Rep 7
07-10-2019, 01:18 AM | #4 |
Rep 106
Drives: '14 BMW M5 CP
I don't mean to be rude but if you don't know what a strut is you should just find a good independent shop to look at it for you and get you straightened out.
07-10-2019, 04:32 AM | #5 |
Rep 7
I know a lot about cars but mine english is not the best when it comes to parts and thecnich english. Im writing from Denmark.
07-10-2019, 08:01 PM | #6 | |
Rep 106
07-11-2019, 03:50 AM | #7 |
Rep 7
Shock makes sense for me, hehe. I will have it checked by some mechanic these days. Can not find the fault..
09-06-2020, 02:07 PM | #8 |
Rep 217
Thread revival. So my 2015 just start making this creaking noise. I really only notice going forward at this time and under 5mph. Bar is great otherwise. Was a fix ever determined. Had her up in the air today checking bushings. The rear difff mount bushing was the only one I thought had to much play in it even though I can't see any cracking, but it could just be ripped.
Thoughts? |
09-10-2020, 12:41 PM | #9 | |
Rep 25
09-23-2020, 11:11 AM | #11 |
Rep 217
Finally cured a creak/groan my car had in the rear at low speeds. This was my second time under the car checking bushings. Then, I decided to check all the bolts on the rear axle bracing.
Bingo! The two forward passenger side bolts on brace were missing. But, I was wrong, they were still there. They had twisted and snapped the heads off. 600+ whp and wtq will break things I guess. I got the broken stumps out and replaced all four of the forward bolts with grade 9 instead of the factory grade 8 bolts. Noise is gone for $8 dollars and less than an hour of my time. |
10-12-2020, 09:57 PM | #13 |
Rep 217
Just visit Home Depot or your favorite fastener store. I used Allen head M8-1.25 x 35 mm Class 9 with washers. I tightened them but didn’t torque them.
10-19-2020, 03:53 AM | #14 |
Rep 69
Drives: M6 14 GC frozen grey & 21 M2C
I'm talking about pictures of the two forward passenger side bolts on brace that were missing on the car not the tool you used
10-02-2023, 11:38 AM | #15 |
Rep 15
I know this post is from a long time ago but I had the same exact issue and creaking sound in my front right suspension. So annoying.
31122284978 is the part that was replaced. All is fine and good now. |
12-12-2023, 07:23 PM | #16 |
208
Rep 1,557
Drives: F10 M5 & F85 X5M
Thanks for noting that, the same thing is happening to mine and someone told me it was the bushings. But this part you sent makes more sense.
AW F10 ///M5 AW F85 X5///M BootMode3 STG 2///Project-Gamma Intakes///ActiveAutowerke DPs///Maxton-Design Body Kit @MeisterAutosport @RatedMClub @RatedMRally |
