05-20-2019, 10:16 AM | #1 |
Rep 135
I recently got my hands on a used oem GTS Lip, so i thought i could write a short Review of the Installation.
As expected, the build quality and fitment is perfect. I had it resprayed in satin black, because of a few small scratches, etc. from the previous owner. Installation was a bit tricky because i haven't found any instructions or DIYs, but it's not too hard to figure out how to do it. I had to test fit and cut the bumper a few times to make sure it clears all the brackets perfectly. (Both sides and the middle part) All in all I'm glad I removed the performance Splitters and installed this beauty. (Yes, the cover of the headlight washer broke and i am waiting for the new one to arrive) Greetings from Austria |
9
LostPanda276.00 sterile stork373.00 Banana Hammock3771.00 leemik509.00 Justin@autocouture202.00 Drifter2090911.00 T!m3369.00 Sthbaysam95.00 roastbeef11591.50 |
05-20-2019, 11:12 AM | #2 |
coupe la goon
373
Rep 1,644
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
Thank you for sharing! I've been dragging my feet with installation of my kit. If you had to do it over again anything you'd do differently? Lessons learned?
05-20-2019, 12:09 PM | #3 |
Rep 1,036
Wow that lip is perfect, but wouldn't expect anything less for the $$$. Thanks for sharing, love it!
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
05-20-2019, 02:25 PM | #5 | |
Rep 135
The only thing i would recommend is to cut out enough from the bumper. The brackets need a little more space than i first thought. For the brace that holds the lower splitter, i've just bolted on the brackets with the screw that goes through the air ducts and installed the middle part, before drilling the holes for the rivets. Sorry for my bad english, I hope you know what I mean |
sterile stork373.00 |
06-01-2019, 07:13 AM | #9 |
Rep 350
Looks great! I ordered and installed mine (upper only) and love how it really finishes off the front end. Next up paint and install the OEM Euro bumper that took only 4 months to get here. LOL
Your E92 M is a great example. Classic combo done well! |
06-02-2019, 05:46 PM | #10 |
Dom
1080
Rep 1,719
Nice! Mine has held up really well, its too bad these aren't readily available anymore. Only way I'd get rid of mine is if I went OEM GT4 front lip.
06-02-2019, 07:16 PM | #11 |
Rep 1,036
Does the upper lip utilize the mounting brackets too, or is that only if you use the lower splitter in conjunction?
06-04-2019, 09:02 AM | #15 | |||
Rep 135
Thank you! Quote:
Yes, a GT4 lip would be awesome! Thank you! Quote:
They are not easy to find |
06-04-2019, 10:16 AM | #16 |
2746
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
06-05-2019, 08:05 AM | #17 | |
Dom
1080
Rep 1,719
OEM GT4 I found on Turner's site but it's close to double what I paid for the OEM GTS. https://www.turnermotorsport.com/p-4...ront-splitter/ |
06-05-2019, 02:01 PM | #18 | |
2746
Rep 6,734
'23 X7
ebisu81079.50 |
06-13-2019, 06:00 PM | #19 |
Rep 391
My ModeCarbon went for a ride at the track.... I need to get an OEM setup
Untitled by Chris, on Flickr Untitled by Chris, on Flickr
-Chris
2011.75 M3 E90 Jerez ZCP Stripper 6MT - 2019 Camaro ZL1 1LE 6MT - 2018 F80 M3 Individual Hera Blue Mica on Cohiba 6MT - 2022 F150 Raptor Instagram: CCOHO93 |
07-15-2019, 03:11 AM | #20 | ||||
Rep 135
That GT4 lip is expensive.. but i think i still prefer the look of the GTS lip. Quote:
Drifter2090911.00 |
