01-17-2019, 07:00 PM | #1 |
Rep 218
TopView camera guides mis-aligned
I've been running into this thing ever since my 2014 F15 was updated at the dealership, i coded everything back to my original settings and only shortly after noticed that my rear view and top view camera guides (red lines) were wrong. They aligned up perfectly with the turn ratio of the truck before (when i bought it), anyone else have this issue? Could it be a coding or calibration thing?
To the right it lines up almost perfect (same with reverse camera) To the left the red guide lines are completely to the side and not even close to the real turn ratio of the car. I know its a stupid issue but i cant help but feel i might have messed something up in the coding. |
01-18-2019, 12:56 AM | #2 |
Rep 1,343
Drives: 2015 BMW X5 xDrive 35i
Sounds like it is a calibration issue. Your pictures aren't showing up for me, but from your description it sounds like calibration.
2015 BMW X5 xDrive 35i-Current
2016 BMW X4 xDrive 28i-Sold 2014 Lincoln MKX-Sold |
01-18-2019, 08:41 AM | #3 |
Rep 218
Hi! sorry about that, here are the links. What do you think?
To the left https://www.dropbox.com/s/mjxyk95549...20PM.jpeg?dl=0 To the right https://www.dropbox.com/s/ps7klqs09z...20PM.jpeg?dl=0 What tool is needed to calibrate? |
01-24-2019, 01:07 AM | #4 |
197
Rep 535
Try rheingold
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi |
01-25-2019, 06:21 PM | #7 |
Rep 145
Sometimes a camera must be reinitialised.
For this reason, a new calibration of the affected camera must be triggered. The affected camera is calibrated automatically in the background during the journey. So that a new calibration can be triggered successfully and quickly, ideally, the following must be observed: Top rear side view camera must not be activated.Calibration is possible only in daylight.Driving speed of 15 to 25 km/h.Hold steering wheel straight.Clean camera lenses.Duration until first valid calibration about 15 minutes.Use a dry, even road for the journey for the calibration. Check whether the re-calibration has been successfully initiated: Stop the vehicle.Press the camera button on the centre console. If a white triangle can be seen in the upper corners of the display, then the calibration was successful. https://www.newtis.info/tisv2/a/en/f...era/1VnXEMkRvi |
01-25-2019, 08:16 PM | #8 |
197
Rep 535
I once had this issue, and saw the option of starting the recalibration in rheingold. Fortunately, just went to the dealer and they fixed it within an hour so never went through it myself. I think you start the process in rheingold, then drive on a clear straight road with marked lines and it saves the calibration.
