12-06-2018, 12:58 AM | #1 |
Rep 83
Eco Pro mode setup as default
I've set my F15 to Eco Pro mode , drove for some time. Then parked and turned the car off. Came back after awhile, turned car On and see that the car is in Comfort mode. Is there an option to set the Eco Pro mode as default mode?
12-06-2018, 01:01 PM | #5 | |
Rep 748
https://f15.bimmerpost.com/forums/sh....php?t=1391908 https://f15.bimmerpost.com/forums/sh....php?t=1033991
Ones drove a Reliant Robin. )))
CatalinP591.00 |
12-06-2018, 07:03 PM | #6 | |
Rep 49
https://f15.bimmerpost.com/forums/sh....php?t=1482187 |
12-06-2018, 09:58 PM | #7 |
4146
Rep 7,164
Drives: F90 M5 / F15 50i
Everything coding is in the 2 coding threads of this forum and on the cheat sheets. One for ESYS and one for BimmerCode.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
01-08-2019, 11:08 AM | #9 |
4146
Rep 7,164
You probably didn't code it right man. Not trying to sound like a dick but it works if you do it right. Did mine via the app with no issues.
01-08-2019, 12:33 PM | #11 |
Rep 83
01-08-2019, 02:48 PM | #12 |
4146
Rep 7,164
I posted it literally right above....
01-08-2019, 02:55 PM | #13 |
Rep 83
I'm using ESYS with ENET cable.
If you are referring to 2 links that artem123 provided, I followed it. the cheat sheet that was in the thread has 3 codes related to the driving mode. I set them up as per that spreadsheet. |
01-08-2019, 08:36 PM | #15 |
Rep 83
01-08-2019, 11:08 PM | #16 |
197
Rep 535
Ok, here is the deal, I will give you my bluetoooth adapter just use bimmercode app (heck you can use my phone and do it for free).
Why - I tried to code this and a few other times a few times with the cheatsheet and esys and was never successful. Then I coded it with the bimmercode app and it works beautifully. Maybe the cheat sheet isnt complete or accurate. Most of it is derived from F10 and F30 sheets from a few years ago. I am in Vancouver too.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi |
yober34.50 |
01-09-2019, 07:02 AM | #17 | |
4146
Rep 7,164
But ya I love the app. Been using it since I got the X to code all my stuff. But do know how to use esys as well. Just don't need to. Glad to hear the brakes can be done with the app as it is more convenient.
01-09-2019, 11:28 PM | #18 |
Rep 83
My original settings for drive modes were as in the photo attached below.
I've coded as per the cheat sheet as following : BDC_BODY > 3023 > TCM_MSA_DEFAULT_OFF Default value : "nicht aktiv" Changed value: "aktiv" BDC_BODY > 3023 > TCM_MSA_ECO_MODE Default value : "FES2" Changed value: "nicht aktiv" BDC_BODY > 3023 > TCM_MSA_MEMORY Default value : "aktiv" Changed value: "aktiv" But the car still defaults to COMFORT mode at each startup. And Auto Start/Stop function stopped working. I want the car to memorize the last driving mode. And keep the Auto Start/Stop function active. Could someone advise how to setup the proper values ? Last edited by yober; 01-10-2019 at 01:42 AM.. |
01-10-2019, 05:45 AM | #19 |
Rep 627
Drives: X5 F15 M package
Buddy, do yourself a favor (and is as well) use BimmerCode. If any, their support is responsive and will help you if it fails.
Esys does not have any support but our kind forum people. |
01-14-2019, 10:29 AM | #20 |
Rep 83
The coding for memorizing the last drive mode has been attempted with BimmerCode , thanks to local forum fellow sahiljain22
Unfortunately this function still doesn't work. Any idea which other code settings must be altered? |
01-14-2019, 08:39 PM | #21 |
197
Rep 535
yober will be glad to report this has been fixed. Both ICM and BCD modules needed the coding. Interestingly the codes for saving driving mode did not exist in esys on his car in ICM when he searched but bimmercode was able to do it.
Maverik259 is right though, bimmercode is tricky. Just the latest update allows coding ICM again, but seems like expert mode is gone. Does anyone know if I VO code, can I restore FDL settings from bimmercode?
yober34.50 |
01-15-2019, 09:52 AM | #22 | |
4146
Rep 7,164
