10-24-2018, 09:51 PM | #1 |
#savethemanuals
2461
Rep 1,988
Getting this display about my battery
Is there a simple fix? Do I need a new battery? I do have an Akra Exhaust with controller? Thanks in advance!!
10-24-2018, 10:23 PM | #2 |
904
Rep 1,004
Drives: 2008 BMW 135i (E88 N54 6AT)
Yeah, same with mine. Buy a Ctek charger and give your battery a full charge once a week or whenever you're not using the car for a few days.
If problems persist, you may be due for a new battery. |
seis-speed2461.00 |
10-25-2018, 02:21 AM | #3 |
4981
Rep 2,269
If you're on your original battery; you need a new battery.
don't read this. too late...
10-25-2018, 09:09 AM | #5 |
Rep 93
I get this too. Once I put it on the ctek charger, It goes away. FYI, I hook it up under the hood & run the cable out near the windshield so hood can close completely.
10-25-2018, 09:56 AM | #6 |
Rep 32
I'm having the same issue. I'm on my original battery, so am planning to replace.
Does anyone have the current part number for the correct battery? According to RealOEM, the part # is 61217553951, but I'm not able to find that anywhere online or what it's been replaced with. Also, does anyone have experience with Costco's battery program? Prices seem quite reasonable and they always have excellent service so I'd be amenable to buying a battery through them and having it installed/registered at the dealer. Thanks! |
10-25-2018, 11:44 AM | #7 |
Buck Sgt
144
Rep 355
I have the same thing few months back because I've been driving my GT3 to add miles during the break in procedure, so the 1M been sitting in the garage for couple of months, but since I've been driving it past months or so, that warning lights goes away and haven't came back. I do have a charger, but opt out of using it unless necessary. So go out and just drive it, and don't garage it, your battery will slowly drain if you don't drive it, but not dead.
10-25-2018, 11:46 AM | #8 | |
Buck Sgt
144
Rep 355
10-25-2018, 11:59 AM | #9 | |
#savethemanuals
2461
Rep 1,988
10-25-2018, 05:46 PM | #10 |
904
Rep 1,004
10-25-2018, 06:07 PM | #11 | |
904
Rep 1,004
Otherwise, the first step is 'diagnosis by treatment' - replace your battery with a new one of the biggest capacity you can fit. Also, it's generally not a problem with our cars since the battery is so well protected - but before you suspect anything else, it'd be worth checking your battery terminals connectors are tight, clean and making good contact. Only after you've done all that and in the very unlikely event that you're still getting the problem with daily driving and a new battery, then I'd suspect the alternator (or charging circuitry). |
seis-speed2461.00 |
10-25-2018, 07:41 PM | #13 |
Thread killer
646
Rep 1,896
If it’s the original battery it is simply a matter of time before you get stranded. Mine started acting “odd” like this - the straw that broke the camel’s back was when the low battery warning came up after sitting in line at the gas station with the car off and radio on for 30 seconds.
seis-speed2461.00 |
10-26-2018, 09:50 AM | #14 | |
Rep 32
Thanks! |
10-26-2018, 10:14 AM | #15 |
851
Rep 2,278
Guys, a battery lasts anywhere between 3 and 12 years (mine is 10½). It's stone cold simple; buy a Deltran, Ctek or Schumacher battery maintainer and use it over night once a week unless you're driving it almost every day. Driving the car simply won't bring an "older" battery up to 100%.
If you have a number of cars, consider those new glove box size lithium battery packs. Our Costco has both Deltran and the battery packs. |
10-26-2018, 11:21 AM | #16 |
Thread killer
646
Rep 1,896
10-27-2018, 05:49 PM | #17 | |
Buck Sgt
144
Rep 355
seis-speed2461.00 |
11-02-2018, 01:46 PM | #19 | ||
Rep 1,064
I just took my X5 there and was not happy! Scratched my rims, messed up gasket replace on my TPMS and was losing air...was a mess! Ended up taking it to the dealership to sort out! FYI - I love Costco and have for 10+ years....but, won't go back for tires to save $100 bucks anymore. |
seis-speed2461.00 FIRSTM143.50 |
11-02-2018, 01:51 PM | #20 | |
#savethemanuals
2461
Rep 1,988
Costco is awesome, but maybe not for enthusiasts, JMO. |
11-03-2018, 12:44 PM | #21 |
403
Rep 1,620
wonder if your Akra solenoid may be connected to a constant power source. you may want to make sure it only works when the car is on. you can check this by checking for the little light on the module in the trunk. if its on when the car is off, you need to move it to another power source. i connected mine to the cigarette lighter circuit
2023 G80 M3 2020 F87 M2C 2011 E82 BMW 1M Series Coupe Check me out at Point.Shift.Drive (YouTube) |
seis-speed2461.00 |
11-03-2018, 08:45 PM | #22 | |
Buck Sgt
144
Rep 355
Tornado1M1222.50 |
