      07-05-2018, 06:06 PM   #1
penet05
Drives: 2014 X5 Sdrive35i, 2013 328i
Water in passenger side footwell
After a hard rain yesterday, I realized the foot-well of the passenger side is soaked with water. Definitely, window was closed. What can be the issue? Thanks.
      07-05-2018, 06:16 PM   #2
DuSh
DuSh's Avatar
2114
Drives: F15 X5 50i
You need to carefully look around and find the source where water is coming from. Check glovebox, door panel, A pillar and lower portion of door - maybe you can still see water droplets or something to diagnose location it's coming from. Depending where the water was coming - it may be several things.
      07-05-2018, 06:47 PM   #3
penet05
Is there any AC drain hose on the passenger side of the footwell? I saw a thread which people addressed their driver side footwell water issue with fixing the hose in the driver side footwell, but I don't know if the car has also another one in the passenger side?
      07-05-2018, 06:49 PM   #4
deutsch100
deutsch100's Avatar
4036
Drives: i7 60, XM, M3 Comp, 911 GTS
In some older BMWs, this was a clogged drain from the sun/moonroof area.
      07-06-2018, 09:17 AM   #5
smyles
Drives: '21 X5
Sunroof drains and/or under the hood near the windshield bottom corners - leafs and dirt collect there and clog the drains.
Tags
footwell, passenger side, water
xbimmers
