BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Mporium BMW
      06-21-2008, 01:39 AM   #1
Kadarin
Ambassador of Crunk
Drives: SG/blk '08 E92 M3
850 miles and service needed?
I'm in the process of breaking in my new 6MT M3, and while I tend to drive it pretty aggressively, I do stick to the letter of the instructions in that I don't go full throttle, nor do I take it over 5500rpm, and I haven't exceeded 100mph. I've maybe hit full throttle once by accident for just a split second, and I've exceeded 5500rpm maybe once or twice, also by accident, and even in those cases didn't exceed 6000rpm.
So now when I start the car I see the Service Required message in the nav window. Is this out of the ordinary, or expected given my aggressive driving?
Should I cut back a bit? It's hard because the car is so damned much fun to drive...
      06-21-2008, 02:29 AM   #2
MDCTFTW
123
Drives: E92 DCT
Early warning. Go in when it says to get your first oil change.
MDCT ... so you can drive and eat a hamburger at the same time.
      06-21-2008, 05:47 AM   #3
RDM3
RDM3's Avatar
Drives: '23 M4 Comp xDrive
Its yours have fun with it plus its covered under warranty
'23 M4 Comp xDrive, '21 M340i xDrive, '14 i3 REX, '13 X1 XDrive28i M Sport, '11 ActiveE Alpine White Electric
'08 E90 M3 Retired.
      06-21-2008, 08:10 AM   #4
rai
rai's Avatar
Drives: M3 coupe with DCT
is there any countdown mile display? Or is the first service always at 1200 miles??
I am at 900 and counting
      06-21-2008, 11:18 PM   #5
Jdebitjr
Jdebitjr's Avatar
Drives: 2008 and 2015 M3 Sedans
As stated below, just an early warning--when you first crank up the car--it should tell you how many miles until the service--should be at 1,200 miles.
m3post
