03-22-2018, 04:03 AM | #1 |
Rep 20
MPe muffled and quiet after 45 minutes
Hi all - wondering if anyone can shed some light..
I drove from Sydney to Canberra on the weekend, and by the time I arrived in Canberra the sound of my exhaust had completely changed - it sounded totally muffled and had lost all the rasp - since the trip when the car/exhaust is warmed up it is sounding the same, totally different to how it used to be (sounds almost like a standard exhaust again) Setup 2016 F80 ZCP MPe with about 11,000kms Valve controller I have checked to make sure the valves are open and can't think of anything else that could be causing this - any ideas? |
03-22-2018, 02:47 PM | #2 |
279
Rep 435
MPE muffler is prone to crack..
Inspect the rear section since such issue may cause change in sound http://f80.bimmerpost.com/forums/sho....php?t=1296326 |
03-22-2018, 05:42 PM | #3 | |
Rep 20
03-22-2018, 05:45 PM | #4 | ||
985
Rep 1,885
03-23-2018, 04:04 AM | #5 | |
Rep 20
Is there any easy way to tell if there might be an internal/baffling issue without opening it up? |
03-23-2018, 04:06 AM | #6 | ||
985
Rep 1,885
Even if it's out of warranty - if you bought it from BMW I would give it a try - there are known issues with this exhaust and they might be willing to cover it. No harm in trying. |
03-23-2018, 04:14 AM | #7 | |
Rep 20
Essentially trying to rule everything out before i get it opened up - the change did coincide with the software in the car being updated to solve a bluetooth issue so i'm racking my brain to figure out how and if this could have affected it |
03-23-2018, 08:08 AM | #8 |
3096
Rep 4,400
Drives: 2022 F97 X3M Comp LCI
valves are probably stuck (closed)? double check looking through the tips with a flash light. very easy to tell.
my valves were stuck as well (but open, which rattled like hell).
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
03-23-2018, 04:32 PM | #9 |
Rep 20
03-23-2018, 09:07 PM | #11 |
985
Rep 1,885
03-23-2018, 10:14 PM | #12 |
Rep 20
