03-16-2018, 11:19 AM | #1 |
Rep 7
Drivetrain Malfunction
I recently tuned my 2015 F82 with BM3 and F80Paul's Custom 93 map. I was accelerating in 2nd gear (nowhere near WOT) and got a drivetrain malfunction and limp mode. I shut the car down and it restarted and drove with no issues. When I got home I read the codes and had the following:
1E5A20 engine torque limitation: exceeded maximum nominal torque permanently 1F0526 DME, internal error, safety function: torque comparison Are these anything to worry about? My car just went out of warranty and I'm a little worried about the crank hub issue. Thanks for the help. |
03-16-2018, 12:26 PM | #3 |
335
Rep 4,633
As always, contact your tuner first for advice..
Flash back to stock.. delete codes and try to re-create..
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
03-16-2018, 12:41 PM | #4 | |
Rep 62
03-16-2018, 12:43 PM | #5 |
Rep 62
Good advice. The DTMAL happened to me twice in two days, so may happen regularly. In which case flash back to stock for a couple of days and see if the issue comes back. That will help isolate the issue to the map, or something else.
03-16-2018, 12:47 PM | #6 | |
Rep 62
Anyway, these things happen from time to time. I’m comfortable that help was on hand by Paul when I needed it. That’s as reassuring to me as something being perfect. Happy to continue using Paul. Last edited by OreoGuy; 03-16-2018 at 03:10 PM.. |
03-16-2018, 12:49 PM | #7 |
Rep 233
If you had a crank hub issue, you would not have restarted and been OK.
You have a DCT? Sounds like the car detected too much torque and got very upset about it. There is likely zero mechanical damage, this is a failsafe. |
03-16-2018, 12:57 PM | #8 | |
Rep 250
Just contact me through the tune in BM3 for a fix. The issue has arisen with my recent pedal mapping changes for part throttle smoothness. A few forum members have been awesome to help me dial in part throttle mapping for track duty. But the changes have cause this DTMAL to occur on some cars. Dzenno and Halim are looking into the issue to see if there are some additional tables required or some other changed need for reduced pedal mapping on these ROM versions. For now, I will reset your pedal mapping settings back to stock. I'm sorry for the inconvenience. Paul |
03-16-2018, 03:12 PM | #10 |
Rep 719
Hey Paul none what so ever.
Right at the start of bm3 when it got released i had it happen once with ots map, dzenno and halim got it sorted quickly Since than no problems and tested your pedal map with zero issues. Could be isolated to certain roms maybe Paul. |
03-16-2018, 03:17 PM | #11 |
Rep 250
Yes, it definitely doesn't happen on every car, and resetting the pedal mapping back to stock seems to be the fix for those that get the DTMAL. It's frustrating because we have worked so hard on these pedal smoothness changes. I'm hoping it's just some torque monitoring tables for certain ROM's that are not exposed in the editor.
whoop_ass355.00 |
03-16-2018, 04:40 PM | #12 | |
Joint Chiefs of Staff
4924
Rep 116,006
Nothing to worry about. Mike |
03-16-2018, 11:00 PM | #13 |
Rep 7
Thanks for the reassurance everyone. I flashed back to Stage 1 and haven't had any issues so definitely don't think there is any damage done.
Thanks for the response F80Paul. I will try the update and let you know how it works. |
03-17-2018, 05:17 AM | #14 | |
Rep 719
nothing would happen at all. |
03-19-2018, 10:29 PM | #16 | |
Rep 1
I had the exact same thing happen to my car while I was on the track. it happened 3 times, every time I switched the car off and on, and the problem was solved. after the 2nd day on the track, my car lost complete power. it feels like either the turbos are not spooling or they are bleeding. On the sports display, max power at full throttle is 180 hp. there are no fault codes in the car vehicle information, but after using an OBD tool, it shows cats error and o2 sensor error. what could be the reason for losing the power ??? |
