03-11-2018, 09:48 PM | #1 |
35
Rep 156
Active autowerke downpipes f80
Just purchased a set for 500 bucks. I think it was a pretty sweet deal.Anyonebhave experience installing these , do I need to look out for anything tricky or is it pretty straight forward?
03-12-2018, 12:49 AM | #2 |
279
Rep 435
Very straightforward working with the car on a lift. OEM pipes removal is what makes the overall install a little hard since the cats are huge. The AA pipes after that just slip in no issues.
Keep in mind it will cause a CEL so a tune/exhaust module is required |
03-12-2018, 06:39 PM | #4 |
24463
Rep 191,414
Congrats!!
Make sure to post pictures and share your thoughts on the downpipe
03-13-2018, 09:45 AM | #5 |
255
Rep 490
If you don't want a CEL, I have heard from a couple forum members these work well: http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
One of them has been using it for 2 years now on his M2 and no issues. |
10-22-2019, 07:20 PM | #6 | |
Rep 14
10-29-2019, 07:30 PM | #7 |
Rep 1,356
AA midpipe will not throw a cel with stock downpipes. I have had it on both of my f80's and never got a cel. Keep the primary cats and you will not have a problem.
10-29-2019, 11:28 PM | #8 |
867-5309
76
Rep 308
Drives: F80 M3 ZCP and E36 328i
i had AA downpipes installed a few weeks ago and the CEL went away after a short drive, no idea why. car was 100% stock at the time.
does your city/county do emissions testing? |
10-30-2019, 08:28 AM | #9 |
Rep 319
I installed VRSF downpipes 3 days ago. Did it in my garage with just the passenger side lifted. Pretty straight forward. Unclip the front o2 sensors from the engine bay which is located underneath the charge pipes. Very little access below to break lose the o2 sensors. V-bands will be clamped on pretty good after loosening the 13mm. Use a long extension and tap it loose. With the exhaust, I took off the center support and also the 2 rears rubber support which are colored red held by 1 13mm bolt each. This gave me plenty of room to maneuver the downpipes in/out. As far as the secondary o2, I installed spacers from amazon which were $10 for 2. No CEL yet. I'm also running JB4 so not sure if that eliminates the CEL but according to the new revision, JB4 no longer deletes codes automatically.
M4 Yas Marina Blue
F32 Estoril Blue |
10-30-2019, 04:20 PM | #10 | |
24463
Rep 191,414
sicck_m4167.50 |
10-30-2019, 04:49 PM | #11 | |
Rep 92
