02-28-2018, 06:26 AM | #1 |
Rep 41
Need help!!! BM3 issues
I just tried to flash my F80 with BM3 for the very first time and it failed. Battery charger hooked up 13.5+ volts, all doors closed, AC off, latest software agent, great internet connection, etc.
Two different errors. Preconditions not met and Internal error. My F80 is now bricked in my driveway and Bootmod3 help portal is down. Please if anyone could help me out I'd appreciate it. Car will not start, trunk will not open. |
02-28-2018, 06:32 AM | #2 |
Rep 1,184
Did you make sure to turn off any firewall or antivirus? I know that caused issues for some? Their tech support works I just tried it did you try the right link?
https://bootmod3.atlassian.net/servi...tomer/portal/1 |
proTUNING Freaks4512.50 FSociety3816.50 |
02-28-2018, 06:41 AM | #3 | |
4513
Rep 1,862
Drives: powered by bootmod3
Tech support is hosted by Atlassian. Its one of the largest tech support ticketing and other collaboration software as a service providers, not something we've built. Them being down is almost like Twitter or Gmail being down, highly unlikely. In addition, any emails to our support at protuningfreaks dot com also generate a support ticket. Make sure you sign up with a separate login on the Tech Support portal. It doesn't use your bootmod3 login. Last edited by proTUNING Freaks; 02-28-2018 at 06:53 AM.. |
FSociety3816.50 |
02-28-2018, 06:51 AM | #4 | |
4513
Rep 1,862
02-28-2018, 06:53 AM | #5 | |
Rep 41
02-28-2018, 07:02 AM | #6 | |
4513
Rep 1,862
http://f80.bimmerpost.com/forums/sho...&postcount=637 We've reached back out through the ticket to you. Let us know and we'll remote in and have a look. |
FSociety3816.50 |
02-28-2018, 08:07 AM | #7 |
Rep 127
no offense guys, but maybe it's time to recommend that customers not attempt this on their own until all the bugs are worked out. I feel like I'm reading one of these posts every day.
02-28-2018, 08:21 AM | #8 |
Rep 96
I had 0 problems like most people, not all BM3 customers are here and the big majority only post when they have a problem and then they disappear.
02-28-2018, 08:27 AM | #9 | |
4513
Rep 1,862
As of now there are no known issues with the offline flasher or unlock. In the odd chance a fuel light error comes up after a flash the online recode is there to clear that up. McAfee and similar network protection/firewall tools will cause issues if left turned on but it can be anything rally and the more people use the system out in the wild we'll see it being used in various scenarios as people use software in different ways. It can also be a bad ENET cable at times as the guys offering coding can attest to seeing over time. There are now over 240 active offline flasher users and its our default flash option used not just by the S55 customers but also N55 EWG/PWG, N20/N26 and as of yesterday N63tu/S63tu. We reached out to the OP to help and see what may have been root cause but he's away until 430-5pm today. We know and have screenshots of other tools failing as well and have emails from users who have switched to BM3 due to similar fails with other solutions. We won't share them here but do keep in mind that usually what's posted is about an issue and someone wanted to simply get as much attention to it as possible at a given time to resolve it asap, and its only natural to do that. We typically get instantly messaged on facebook, here, instagram and only then, maybe/hopefully, on our tech support that really should be the go to support channel but that's life. |
02-28-2018, 08:48 AM | #10 |
Rep 1,413
Drives: 2020 X3MC
I cant stress the anti-virus enough. My car did the same thing as yours and we got another set of eyes to remote in and within a couple minutes he saw the securities running on my laptop. Disabled them, reflashed to stock remotely, then we did the flash for tune and TCU. Both went thru without any hitch whatsoever after that friggen anti-virus and firewalls were disabled!!
I have been in your position and the first time I ended up getting the car re-programmed at the dealer unfortunately but Dzenan was at the ready every time i needed him so he will get you squared away. |
02-28-2018, 08:49 AM | #11 | ||
Rep 41
02-28-2018, 08:50 AM | #12 | |
Rep 41
02-28-2018, 08:06 PM | #13 | ||
Rep 41
FSociety3816.50 |
03-01-2018, 02:07 PM | #16 |
172
Rep 2,373
This is almost always much more an issue with whoever is flashing the car and not an issue with something PTF has provided. Usually its voltage-which happens. Thankfully PTF is awesome at support and helping to remedy the situation!
FSociety3816.50 |
03-01-2018, 02:59 PM | #17 |
#dubspec
6345
Rep 5,201
this is exactly why they recommend a charger on the battery. strange how yours was hooked up and still had a voltage drop. Dzenan recommended a few things to me before my flash and everything went butter smooth. extremely happy with bm3!
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
FSociety3816.50 |
03-01-2018, 03:31 PM | #18 | |||
Rep 102
2015 BMW M4 Mineral White
2018 Audi RS3 ? on the way |
FSociety3816.50 |
