02-27-2018, 02:43 PM | #1 |
633
Rep 644
Long Term E85 Use: A Discussion
Hello -
There seems to be alot of people switching to full E85 on the stock fuel system. To relieve some of my own concerns and likely others regarding switching to full E85, both in the short term and the long term, I wanted to get a discussion going about what we're seeing or thinking we may see down the line regarding cars using the stock fuel system and full E85 for 10-25K of mileage - specifically fuel pump wear, line degradation, injector buildup, etc. Please comment with your experience or discussion points. Last edited by GlazierGlaze; 02-27-2018 at 02:53 PM.. |
02-27-2018, 03:07 PM | #2 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
Long term E85 use should not cause any issues these days. The E85 is much cleaner than was was available years ago.
OEM fuel lines should easily be up to the task of long term E85 use. Although you should check the ethanol content regularly from where you fill up. I ran E85 for 6 years straight in my Evo with not a single fuel issue besides needing lots of it (albeit different car)
AlterZgo1537.50 Laoschris491.00 FSociety3816.50 papasmurf_m3454.50 Envy ///M327.00 StrifeM399.00 slaughter.mode882.00 |
02-28-2018, 11:51 AM | #4 | |
2637
Rep 2,809
All modern fuel systems are built to handle ethanol, as even regular pump gas is E10 (10% ethanol) and there is actually a push to increase pump-gas ethanol percentage to E30(30%) in the US. Long-term E85 usage is only an issue if you don't run a tank of pump gas through the system every 3k miles or 3 months (whichever is sooner). Running pump-gas through the system regular intervals helps clean the fuel system. Ethanol is an alcohol fuel and alcohol is hygroscopic, meaning it absorbs moisture. So care must be taken to not allow E85 to sit for long periods or be stored in places exposed to moisture. I don't recommend keeping E85 in your fuel tank for long periods for cars that are being stored or that don't get driven a lot. For the latter, it's best to keep a full tank so as to not have any air in the tank that the E85 could pull moisture from. It's also important to spot-check your E85 using a simple ethanol tester ($12 on Amazon) and that once you find a good pump, always use that same pump if you can (again spot-check every few fill-ups). If care is taken, E85 is an amazing fuel and none of the details above should deter you from using it. p.s. As Chet said regarding his EVO, I too had an EVO (VIII) that ran 100%E85 for about 8 years straight with not a single issue and that car had an archaic fuel system as compared to today's standards and especially when compared to the S55's fuel system.
2016 BMW ///M4 ZCP - President / Master Calibrator | JordanTuned, LLC (www.jordan-tuned.com)
IG and Twitter: @CaryTheLabelGuy |
12
chetrickerman10446.50 TurboAL471075.00 FSociety3816.50 AlterZgo1537.50 shellman091119.00 M Turbo21.50 Envy ///M327.00 papasmurf_m3454.50 luchocamp259.50 McBobby Jr212.00 slaughter.mode882.00 bobbyf807.50 |
02-28-2018, 02:42 PM | #5 |
Rep 966
Has anyone that ran 100% E85 on a stock fuel system on the S55 engine checked fuel injector seals and or fuel pump components yet to confirm that the fueling will not damage seals.
Not to judge your comment but assuming the late model car fuel systems can handle E85 and knowing if it really can before it starts to possibly had a negative effect would be nice to see clarification. |
02-28-2018, 03:52 PM | #6 | |
2637
Rep 2,809
That said, modern fuel systems that have any rubber in the system is made with ethanol-proof rubber due to the amount of ethanol already in pump fuel and a growing push to increase ethanol in pump fuels in the future. I have run E85 and high ethanol mixes longer than anybody in the world (for the S55), since I was the first tuner in the world to figure out that the S55 could run straight E85 and to reverse engineer the tuning involved to actually make it happen at stock boost, much less these very elevated boost pressures i can tune for now (even on aftermarket turbos). I have not had a SINGLE issue on my development M4. I follow my own advice and run a tank of pump every 3k miles or 3 months (whichever comes first) and I don't allow the E85 to store for long periods.
FSociety3816.50 schnell1982346.50 AlterZgo1537.50 Tall Tom Cruise1013.50 Chris@VargasTurboTech1934.50 bobbyf807.50 |
03-04-2018, 12:01 PM | #7 | |
not good, but bad
333
Rep 361
I reached out to one of CA's largest e85 distributors and they provided some great info, more on my blog here www.*************/howie85
Here's an excerpt about California e85 Quote:
03-04-2018, 02:04 PM | #8 | |
Enthusiast
248
Rep 304
papasmurf_m3454.50 |
03-07-2018, 09:08 AM | #10 | |
Joint Chiefs of Staff
4927
Rep 116,037
This is important information! Mike |
08-16-2019, 08:02 AM | #11 |
Rep 233
How long is too long for it to be stored in the tank? Would a long drive once every 4 weeks or so be ok?
08-16-2019, 09:10 AM | #12 |
Rep 35
I came from an Evo 9 that ran E85 for 9 years . I did store the car on 93 pump during winters. Only issue I had was running out of fuel due to injector sizing. As you need more E85 compare to pump gas .
08-16-2019, 04:57 PM | #13 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
I try not to let the fuel sit for longer than 4 weeks. If it does, I just drive the car without going WOT until that tank is low and I fill up with fresh E85.
Chris@VargasTurboTech1934.50 |
08-22-2019, 02:10 PM | #14 |
1470
Rep 3,157
I had a fuel injector get stuck open while I was religiously using a top lube fuel treatment with every tank. Not exactly sure what caused it but that's the only issue I have run into in about 15k miles. Since then Ive just switched back to a tank of 93oct every e85 2-3 fill ups.
08-22-2019, 07:11 PM | #15 | |
1977
Rep 2,712
Suffice to say, adhering to a 3 month/3,000 mile fuel cycle process is highly important in keeping the injectors from seizing. |
08-22-2019, 08:47 PM | #16 | |
Rep 260
08-22-2019, 08:48 PM | #17 | |
Rep 260
08-23-2019, 12:28 AM | #18 | ||
2900
Rep 3,729
http://www.starbrite.com/item/star-t...ategory_id=587
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
08-23-2019, 12:29 AM | #19 | ||
2900
Rep 3,729
08-23-2019, 12:38 AM | #20 |
1977
Rep 2,712
08-23-2019, 12:18 PM | #21 | |
1470
Rep 3,157
08-23-2019, 01:37 PM | #22 | |
1977
Rep 2,712
The GTR guys swear by this product: https://lucasoil.com/products/fuel-t...th-stabilizers Last edited by FriedPiston; 08-23-2019 at 01:43 PM.. |
