02-23-2018, 06:50 PM | #1 |
228
Rep 502
Meth Controller with Flash Only
For those of you running meth with flash only, what controller are you using and how do you have it set up to ensure safety?
Thanks in advance!!!
Sunset Orange G20 M340i
PAST F80 LCI/M3/AW FBO BM3 Cary Tuned Meth/Pure Stage 2 F36 CB 435i FBO F15 GS X5 50i Tune F10 AW 550i Loaded/Tune/M5 Exhaust |
02-23-2018, 07:03 PM | #2 |
Joint Chiefs of Staff
4927
Rep 116,037
JB4 with a back end flash is a great solution for meth..
You let JB4 control meth. You can also setup a full flash and then the JB4 is only there as a meth controller and dynamically adds boost when meth starts flowing. Mike |
02-23-2018, 07:06 PM | #3 |
Rep 250
I will post later when I’m back to a computer and can post photos. I use a Torqbyte controller and have developed a safety mechanism that will open the EWG’s and dump boost if there is a condition where the WMI pump current either goes too low(tank empty or leak) or too high (line or filter clog).
The safest thing with meth injection is a proper tune and a very solid install using quality lines, fittings, pumps, and controllers. I’ll share more of my experiences later wen I can. |
behindthen0thing839.50 sly1types431.50 |
02-23-2018, 07:27 PM | #4 | |
179
Rep 482
unless your running MHD, the JB4 hasnt been proven to work with other BEF's.... Map 7 is apparently the map to use, I wont have a chance to test and log until spring. I believe Aquamist is running a controller that also integrates with the car, but I havent done much research, I hope someone can also chime in. |
02-23-2018, 07:45 PM | #5 | |
228
Rep 502
I don't want to have to go to upgrade clutches to run this way when flash only guys don't seem to have issue. Looking at all options still so just researching. Want a reliable 650hp/tq think flash with E40 maybe the way to go
02-23-2018, 08:16 PM | #6 | |
Rep 250
02-23-2018, 08:20 PM | #7 | ||
228
Rep 502
Are you familiar with snow performance controllers? I am just running their pump and have a local supplier. Thanks in advance!
02-23-2018, 08:36 PM | #8 |
Rep 250
You can use the EWG portion of the JB4 harness to tap the EWG signal wires. That portion of the harness is also sold separately if you don’t want to splice your JB4 harness. To do this you need a controller that will be able to trigger two relays when the meth pump current draw goes below or above a set point. The Torqbyte has this feature.
CloudVIII227.50 |
02-23-2018, 09:24 PM | #9 | |
4927
Rep 116,037
I know MHD is working on raising their internal torque limiter cap so maybe that will help a bit. Do you have the ZCP trans flash? That also makes a big difference. Mike |
02-23-2018, 09:25 PM | #10 | |
4927
Rep 116,037
Mike |
02-23-2018, 09:27 PM | #11 |
4927
Rep 116,037
For those that missed it another JB4 feature they recently added is an in dash meth flow gauge on the speedo cruise control right. Pretty slick setup.
https://www.youtube.com/watch?time_c...&v=jYlum4j2evM http://www.n54tech.com/forums/showthread.php?t=51540 |
02-23-2018, 09:30 PM | #12 | |
749
Rep 2,108
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
02-23-2018, 09:31 PM | #13 | ||
228
Rep 502
schnell325892.50 |
02-24-2018, 12:14 AM | #14 | ||
228
Rep 502
SYT_Shadow11509.50 |
02-24-2018, 12:22 AM | #15 |
SCHNELL
226
Rep 835
Someone clever look at this concept please?
I tried to provoke some clever (erer) minds in another post re: Brazil factory E85 tune for an F30 that used a generic Ethanol sensor, and also hint at how the GTS ecu is triggering the water spray - use that for Meth. My Christmas wish... a BEF with E85 ability (and safety) built in, with NO piggyback to trigger Meth - use the same pins/loom as the GTS? Everyone is so busy with OBD flash to worry about this?
02-24-2018, 02:21 AM | #16 |
Rep 182
The Brazil N55 flex fuel sensor input uses the same input as one of the MAF sensors on S55 and the input does not alter any candidate port registers on other N55 which are from EU or US.
Similar story with most other I/O where equipment variations leave little clear path for new I/O that is consistent across models. GTS water I/O has uses for some of the pins on other models. These were problems I came across testing MEVD172G flex fuel on Tuesday on the bench, leaving me crying in my coffee. The flex fuel input would be useful for triggering safeties inside the DME if used with port/methanol injection without needing an external controller perform the action. Last edited by BMWcurious; 02-24-2018 at 03:24 AM.. |
Commanderwiggin2056.00 |
02-24-2018, 07:48 AM | #17 | |
3348
Rep 2,009
I run the JB4 & BM3 stack on the BMS meth kit. My dyno hits 620lb/trq (wheel) with the GTS TCU flash and I have never had a slip. After data logging I've noticed that Map 8 produces no manipulation of the BM3 stage 2. However I personally run Map 6 either with zero additional boost or additional whenever I feel like getting rowdy. Meth trigger 1 and default meth safety will keep her safe. The JB4 is a legit meth and boot controller however, I'm interested in seeing how the torqbyte integrates. Upgraded braided lines and nozzles coming this spring. Shoutout to F80Paul for helping me sort out the AN fittings. |
02-24-2018, 09:09 AM | #18 | |
Rep 250
I really don't want to get into a JB4 vs full flash debate. The JB4 served me well and I actually still have it installed in my car but just in map 0 and disconnected from the OBD port. A few things discussed in this thread I'd like to clarify.. Unless something has changed, and this would be good news if it has, the JB4 ONLY has "safety" with WMI while operating in map 8. The JB4 can't do anything with ignition timing so basically what map 8 does is increase boost (above the DME requested boost) and then in theory if it detects a lack of meth flow (via over/under current from the wmi pump) it reduces boost. (side note: by the way without the ability to set the exact over/under pump amperage you will only be able to use the cooling mist pump that comes with the BMS kit, any other pump will change the amperage that the pump draws and thus will break the over/under current threshold safety)((the Torqbyte lets you manually set the over/under current safety setting to work with any meth pump you want)) Again, unless something has changed recently and I did ask Terry for this many times, there is NO meth safety in map 6. only in map 8. Okay, so the feature that lets you use the JB4 to trigger the meth pump, with the JB turned OFF in map 0, is something that Terry made for me over a year ago with a hidden feature in a special firmware. It sounds like this feature has made it's way into the general release? The way it worked when he made it for me was you set meth safety = 4 and then the JB will trigger the pump with 100% duty based on the raw MAP sensor voltage when boost goes over the WMI minimum boost setting. NO safety. Just allows you to use the JB as a basic on/off Hobbs switch. Useful for existing JB4/bms WMI kit guys to go full flash without having to buy something else for sure! Concerning DCT clutch clamping force... There is no table in the DME which controls clutch clamping force. The DCT controls clamping force based on actual DME torque request, which is tied to DME boost. The JB4 allows up to approx 22-23psi boost from the DME at it's input, no more. But 22-23psi is a lot better than stock and so having a BEF will help a lot with DCT clutch slippage compared to using the stock flash. However, I do not believe the torque request sent from a BEF to the DCT is anywhere near that of a full flash with high boost. My car runs 6.0 60-130 with no slope on Stock DCT clutches and zero slippage. Over 700whp with the DME in full control of boost. The meth injection safety mechanism I developed for my car will instantly open the wastgates and then as a result of that the car will go into limp mode. This is exactly what I want to happen IF there is ever a problem with meth flow. I want the motor to stop boosting and I want to be alerted so that I can fix the issue before continuing to drive. If you have a meth leak in the engine compartment you don't want to continue driving with reduced boost, as the JB4 in map 8 will allow. You want to shut it all down and inspect the problem. I sincerely hope I haven't ruffled any feathers with my comments. Again, I have nothing against the JB4 and Terry Burger has always been nothing but extremely helpful to me in the past. I think it's a great plug and play setup that is easy to install and get running on map 8. These are just my experiences and challenges I have had to overcome as I have grown to incorporate much higher flowing methanol injection setups with the need for more precise control over flow throughout different boost/rpm ranges as well as incorporating safety while using larger pumps, etc. -Paul |
02-24-2018, 11:21 AM | #19 | |
4927
Rep 116,037
On maximum calculated torque that is set entirely in the back end flash map. As of right now I believe BM3 has the limiter removed and MHD does not, but I know MHD is working on removing it. Once done you can set the calculated torque to whatever you want. For example, you can set it so 20psi on the flash reports 800lb/ft of torque to the trans, as BMS has done on the N54 back end flash maps. The JB4 reports full boost to the DME up to the flash target so if you set the flash target to 30psi then you're going to have full boost reported up to 30psi regardless of the JB4 settings. Mike |
02-24-2018, 12:13 PM | #20 | |
Rep 250
Meth flow scaling just changes the display and logging so that 100% pump duty shows as 100%, unless something has changed this setting has no affect on anything functionally. There are many variations of the Aquatech pump, different motor versions as well as heads. On top of that, depending on the size and number of nozzles being used the actual amperage being drawn when meth is flowing properly will vary. This requires the controller "safety" over/under pump current thresholds to be adjusted for each install for it to actually work properly. There is no one size fits all setting that will work for every install. The proper way to setup a safety that relies on pump current draw to decide whether meth is flowing or not requires you to log meth amperage draw during system usage, then you set the over and under amperage setting accordingly for that setup. I disagree about the DCT reporting. I have tested this extensively on my car. While there are two torque at the DCT clutch limit tables in the DME which I increase so that they do not become a limit as DME boost is increased, there is nothing to indicate (no logging data channel) that the torque being reported to the DCT is being altered to be different than the internal actual torque calculation that is based on actual load. I know the point where the DCT begins slipping with a JB4/BM3 BEF combo, which I have used. Full flash with high boost holds at a higher torque in my experience. Unless something has changed recently the JB4 cannot handle more than 23psi in the BEF, as it will peg out FF to 0. The JB4 cannot handle a higher wgdc input from the flash than around 22-23psi without fudging the wgdc sensitivity with FUA which would always give me a DTMAL. Has this changed? Is anyone actually running a BEF on s55 that runs more than 23psi dme boost? These are all things that I spent extensive time on back and forth with Terry over a year ago. Would love to know if there have been recent changes affecting these things. That would be good news if it were true! |
02-24-2018, 12:34 PM | #21 | ||
4927
Rep 116,037
For map6 WMI safety you normally use the "safety mode = 2" or "safety mode = 4" options. Quote:
On the calculated torque it's loggable on the JB4 and that is the value sent to the trans to determine clamping force. Higher is better but the trans tables max out at some point also, so more torque reported does not provide additional clamping force. Mike |
02-24-2018, 02:33 PM | #22 | |
Rep 250
CloudVIII227.50 SYT_Shadow11509.50 |
