01-30-2018, 01:07 PM | #1 |
Rep 250
World's First F80 M3 Running on 100% Methanol Fuel (In the gas tank)
Hey guys,
I wanted to share something I've been working on this week. I've recently setup my car with a custom PI configuration that gives me the capability to R&D pretty much any fueling situation I want. I'll explain more about this later but let me cut to the chase: I was able to run a 6.025 60-130 on PS4S's with lots of wheelspin and nothing more than straight Sunoco Methanol in the gas tank. No meth injection on this run. 28psi / 14deg timing / .835 Lambda. Flash only Bootmod3 tune. How did I do that? Methanol is the most demanding (on the fuel system) fuel we have available with it's Stoich of 6.45. So it takes a lot of it! A few weeks ago I installed a Fuel-It rail with 950cc injectors, a Stage 4 LPFP with all new fuel lines, a Split Second flash only injector controller, and a custom 3 way valve allowing me to switch between PI from the gas tank OR from my meth pump/tank in the trunk. I also have a Torqbyte controller which I use to control the fuel-it secondary LPFP as well as my methanol pump in the trunk(which was not used for this test). For this experiment, I switched my 3way valve to feed the PI injectors from the LPFP/gas tank. I added Alcohol top lube to the Sunoco 100% methanol before pouring it in the tank. I first tuned the car on the stock fuel system alone(no PI) using all the tricks I have learned tuning for Ethanol blends. It was quite easy to get into misfire territory by 16psi on methanol, but I was able to get perfect cold starts and part throttle drivability on the stock DI alone. Next, I began dialing in the IAC Split second controller driving the fuel-it rail with the 950cc bosch injectors. I continued to add fuel via PI, adjust the fuel compensation in the flash, and turn up the boost! I arrived at the limit where the HPFP and LPFP pressures could no longer keep up and started taking a dive. That limit with 100% meth was around 28psi. The car is making big power at merely 28psi and 14deg timing, as evidenced by the 6.025 60-130. I attribute it to the great fueling characteristics of Methanol. These motors like Alcohol! My next test will be to add some Methanol injection to this, as well blend some 93 in the tank to bring the content down to around M85 which is safer. Blending ethanol or methanol with gasoline greatly reduces isn't corrosiveness. Even with the top lube added I would never run M100 long term. I'm attaching some photos below showing some of the setup I have as well as the verified Vbox graphs and a BM3 log snapshot from my test. P.S Huge shout out to Steve at Fuel-It for the awesome support and I would like to thank Jesse with Pure Turbos, these turbos he made me that work with the custom inlets that I made have been flawless. You can see from the WGDC in the log that they barely have to work to achieve 28psi up top! |
9
azn_fcuk179.00 PeterPure677.00 schnell325892.50 whoop_ass355.00 Aapparition90192.50 DLSJ5504.00 850_f80m367.00 DrtyJrze707.00 FSociety3816.50 |
01-30-2018, 02:54 PM | #3 |
Rep 1,184
Methanol straight from the fuel tank? That’s a first! Did you have to add more tuning tables to BM3 for tuning or did pretty much the E85 stuff carry over? Really amazing stuff right there and fairly bolton still it seems. I don’t have E85 close by but methanol is in abundance.
FSociety3816.50 |
01-30-2018, 03:07 PM | #4 | ||
Rep 250
FSociety3816.50 |
01-30-2018, 03:25 PM | #5 |
749
Rep 2,108
Impressive
So how does the car's performance compare when running M85 vs E85?
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
FSociety3816.50 |
01-30-2018, 03:41 PM | #6 |
Rep 250
That's a complicated question to answer because the fuel volume requirements are different. But let's say hypothetically you didn't have a fuel volume limit and simply compared M85 to E85 at the same tune parameters (boost/Lambda/timing,etc). I think the M85 would win because OF the effects of extra volume you are having to deliver to achieve the same Lambda. The high oxygen content and combustion chamber cooling effect of running methanol is pretty astounding.
FSociety3816.50 |
01-30-2018, 04:03 PM | #7 |
3348
Rep 2,009
this is some mad scientist shit here..... love it.
Where'd you get the stainless lines for the charge pipes? I've been tinkering with the idea to upgrade mine. |
01-30-2018, 04:09 PM | #8 |
Rep 250
Haha thanks dude. Yeah I’ve been through three iterations of meth lines and finally found something reliable. What you want to use is nitrous lines and fittings. I’m using -6an from the pump to the front of the car and then -4an from there. Summit racing is where I order that kind of stuff.
01-30-2018, 04:23 PM | #9 | |
3348
Rep 2,009
01-30-2018, 04:28 PM | #10 | |
Rep 250
01-30-2018, 04:32 PM | #11 | |
Rep 250
FSociety3816.50 |
01-30-2018, 09:41 PM | #12 |
3348
Rep 2,009
Noted. I think I'm going to overhaul my lines. How'd you run the line? 6AN line looks pretty beefy to run through the cabin and hide under the panels. Did you go outside under the car? Are you running the stealth tank? I'm trying to figure out how to properly get it paired up to the pump.
01-31-2018, 07:13 AM | #16 |
9604
Rep 10,891
Wow...this is pretty crazy. Great work on pushing the boundaries...excited to see your results when you run the M85.
Do you plan to stay at 28psi?
01-31-2018, 07:31 AM | #17 |
Rep 806
Drives: 2016 lci m3 mw
Amazing work , i dont know any technical stuff but how much torque is this thing putting out, just curious as dct apparently not high torque friendly (bmw salesman ahmm) .Turbos look like a piece of art.
f80 m3 lci mw
01-31-2018, 02:44 PM | #18 | |
749
Rep 2,108
So you're using M5 in the tank I assume? Or M1 just like what you'd use for meth injection? |
01-31-2018, 03:33 PM | #19 | |||||
Rep 250
I use Sunoco fuels Methanol. I also add Alcohol Top Lube to it. Grape scented. haha |
FSociety3816.50 |
01-31-2018, 03:47 PM | #20 |
24463
Rep 191,414
Nice!!
02-03-2018, 12:05 PM | #22 |
Rep 681
This is outstanding Paul! Thanks so much for the great feedback and kind words. You are obviously very talented with tuning these cars. I'm excited to see more from you! 6.0 sec on 28psi and street tires is phenomenal! Now get some decent tires on that thing, and re-run the 60-130 with a little more boost!
FSociety3816.50 |
