01-29-2018, 03:31 PM | #1 |
Rep 209
Crank Hub solution feedback/discussion
I would like to get some feedback from the community about the current crank hub solutions that are being offered by Gintani and MAXIMUM PSI.
I am a little nervous pulling the trigger on one of them given the history. They are not that cheap and the install is also lengthy with a day and a half. I do know that the cost of any of these will be way cheaper than replacing an engine if something goes wrong. Which one do you think is better and why or is it like you cannot go wrong with either of them? Thank you very much, Alex |
01-29-2018, 09:50 PM | #3 |
Rep 966
I think there are alot of vehicles not reported on the forum.
I deal with automotive dealerships for work on a weekly basis and when I visit some local BMW dealerships I have talked to tech's and service advisors that I know. They do a fair amount of repairs due to failures on stock cars. I have not asked about this topic in months, I think I will next time I visit to see if the solution that BMW changed "increased torque spec, revised friction washer" was enough for the S55 on an OEM level |
01-29-2018, 10:15 PM | #4 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
IMO, the Gintani design is better, but both should easily be strong enough to handle any power level.
01-29-2018, 10:24 PM | #6 |
Rep 966
Yes.
I also hear that the common failure on DCT is due to excessive "kick down" in 3rd / 4th gear. I find Steve Dinan's information interesting where he notes that there is another area of concern within the engine. Being that he supports BMW race teams, he has no doubt experienced and has the resources to really fix an issue if need be. "Due to the design of the crankshaft, it is known to have the timing chain sprocket spin on the end of the crankshaft, causing the cams to go out of time. In extreme cases, the valves can hit the pistons, causing catastrophic damage. Furthermore, the S55 only has half of a normal crankshaft thrust bearing. To ensure durability we also machine the block to accommodate a full circle thrust main" https://carbahnautoworks.com/product/s55-3-0l-rebuild/ |
01-30-2018, 08:04 AM | #7 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
The majority of people that have this issue have a DCT
cotmfk2058.50 |
01-30-2018, 01:42 PM | #8 |
Rep 209
Thank you all. I just wanted to get some opinions on the different crank hubs that are being offered. It was not supposed to be a discussion about the failures themselves as we already have a quite lengthy thread about it.
I do prefer the Gintani one piece design but it is also quite a bit more $s than the Maximum PSI solution which uses the two hardened pins. |
01-30-2018, 02:15 PM | #9 | |
Rep 966
I only know 1 person who received the Gintani update but then sold the car 1 week later. |
Walmart Parking Lot103.50 |
01-30-2018, 04:04 PM | #10 |
335
Rep 4,633
I haven't heard of a failure in a long time on the boards.. Is this even a thing anymore?
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
01-30-2018, 05:10 PM | #11 |
Rep 1,095
I have the gintani keyed one piece on my car. I would go with mikes design but at the time my car spun I didn't have that option. It's also a lot cheaper lol. So far the gintani has held up great on my car.
2016 M3 Alpine White / Sakhir Orange BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount) |
01-30-2018, 08:13 PM | #12 | |
Rep 966
I have a friend with the original TPG kit when it was 1st released and his DCT M3 has JB4 staked on flash tune, methanol injection and typical bolt on mods and he tracks the car once a month and it never failed. So I'm curious on all the setups of course |
01-31-2018, 10:00 AM | #14 | |
Rep 209
Gintani's is one piece keyed over 2 pieces with pins. |
01-31-2018, 12:45 PM | #15 | ||
Rep 1,095
02-01-2018, 12:27 AM | #16 | |||
Rep 136
02-01-2018, 10:35 AM | #17 | |
Rep 1,095
02-01-2018, 01:56 PM | #18 | ||
Rep 136
02-01-2018, 01:58 PM | #19 | |||
Rep 1,095
