12-09-2017, 11:27 PM | #1 |
329
Rep 742
9CBB Short Circuit. Angel eye out
Hi everyone,
About 2 months ago my passenger side angel eyes went out. I haven't been driving my car much so I didn't care to fix it right away. Just this past week I went to get my angel eyes actually replaced (new angel eyes, blacked out housing). The new angel eyes plugged directly into the existing plug the h8 would plug in to so no splicing or new wiring was necessary. In doing this, I figured it would fix my problem since there wouldn't be any more h8 bulbs. We plugged the headlights in and the angel eyes still didn't work. We removed the headlights, switched the ballasts and plugged them back in. Passenger side still didn't work. We then moved the passenger side headlight entire housing to the driver side and plugged it into the driver side plug. The angel eyes lit up. Keep in mind that even on the passenger side, although the angel eyes didn't work all other lights worked. I scanned my car and I had a 9CBB short circuit fault 2 error. I did some research and came across threads with similar issues. The solution was resetting the short circuit protection fault with Tool32. I downloaded the programs, got them working correctly and tried resetting. The past 2 days with multiple tries I have not been able to get them to turn on. With those familiar with tool32, I didn't just do the angel eye argument, I did all the lights as well and nothing worked. Load inpa after tool32, clear codes and they just come back. Does anyone have any advice or recommendations I should try? I'm just confused since the headlight that doesn't work well works completely fine on the driver side plug so everything within the headlight wiring is fine. Could this be a footwell module issue requiring a replacement? Attached is a picture of codes in the frm from Carly. |
12-10-2017, 07:46 AM | #2 |
4452
Rep 4,010
If it is the FRM it is still under warranty. The problem with that is the dealership will most likely charge you for a diagnosis first. Have you done your airbag or battery cable recalls? If not, then there would be no diagnosis fee and they will catch that the FRM module has issues. I am aware that this does not answer your question..
12-10-2017, 05:13 PM | #3 | |
329
Rep 742
