M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      09-09-2017, 03:18 PM   #1
Rickzg
Drives: audi r8
Vacuum issue major loss in power - please help!
Hi guys, Im hoping someone can help me. Last week I had my car on the dyno, it is a stock 2012 m5 no tune and only an akra cat back exhaust. The car kept going into limp mode at 6k rpm and only making 460bhp crank.
The only error displaying was "120908 Charging pressure control, switch off: pressure build up blocked", the exhaust vacuum pipes are connected and the car drives fine. I have only had the car for 2 months so I am guessing it has been low on power since i purchased it. The garage says the wastegates are not opening fully, and suggest I change the vacuum pressure valves, has anyone had a similar problem to this??
Please help!
      09-10-2017, 12:46 PM   #2
gary_F10M5
gary_F10M5's Avatar
Singapore
Drives: 2014 LCI MCB M5 CP
Please help!
I had the same issue with low boost. Turns out the akra vacuum actuators at the rear were faulty and leaking vacuum pressure. Disconnect and Seal the lines with a screw or tape. Should do the trick.
@garysim1313
      09-10-2017, 12:51 PM   #3
Rickzg
Drives: audi r8
Really?? I will give that a shot!
      09-11-2017, 10:18 PM   #4
Teezus91
Drives: 2012 BMW M5
i had the same issue, changed the actuators and everything was fine.
m5post
