05-20-2017, 03:15 AM | #1 |
Rep 944
Noisy turbo whistle?
Hearing an abnormally loud turbo whistle on the driver side with windows down. Don't remember hearing it before but I did mess with the stock intake hoping to complete a install of RK but ended putting the stock back on. Check all clamps and everything is snug
Do you think it's a leak or does AsD also include fake turbo whistle Car drives normal but never heard a stock turbo car be that loud |
05-20-2017, 06:53 AM | #2 | |
Rep 258
Mine is pretty loud, always has been. |
05-20-2017, 08:28 AM | #3 |
Rep 1,478
Interesting but def seems that my turbo sounds are noticeably louder in last couple months - only thing I changed in that timeframe was to put on a vented Exotics Tuning CF hood but having a hard time believing that that could make the sound so much more evident - also did a cursory check for loose clamps etc and all seems AOK (prob need to look closer).
Anyone else notice a change in sound or volume over time (mine is a 7/2015 build and a daily driver)?
Individual M4 Convertible ED Sept 2014
05-20-2017, 09:59 AM | #5 |
Rep 1,478
Not a question of like or dislike - Have been wanting to use that, thx!
05-21-2017, 01:35 PM | #6 |
18857
Rep 14,141
Drives: G82 M4C X-Drive
I don't hear a whistle, but I do hear a "whooosh". Also, disable ADS for a better quality of life.
05-21-2017, 10:16 PM | #7 |
74
Rep 478
Stock or aftermarket intakes on WOT, you should hear a turbo whine.
Stock or aftermarketing intales at low rpms and decelerating with no throttle, you should hear a Turbo Whistle with catless DP.
2013 E92 M3 ZCP
2014 F06 M6 GC 2017 F80 M3 ZCP |
05-22-2017, 07:22 PM | #9 |
24384
Rep 191,215
If it is very loud get it checked out at the dealership
05-23-2017, 11:15 AM | #10 |
Rep 677
Perhaps there is an Echo
The only time I can hear the Turbos is if I am parked up against a wall on the driver's or passenger's side with window's down. and then sometimes I can hear them when I am driving with elevated RPM levels.
When you have heard the sound more elevated, if you were parked against a wall that the sound of the turbo could echo off of, it may be why it sounds louder than you are used to. I am sure it had nothing to do with you going in and actually modifying the car.....right?
F80 ///M3 LCI SSII Lick the lollipop of mediocrity once and you suck forever. |
05-25-2017, 03:22 AM | #13 |
74
Rep 478
If it is a faint whining sound, that is the sound the turbo makes when the compressor blades spool.
2013 E92 M3 ZCP
