ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      03-27-2008, 12:18 AM   #1
laidback
137
Drives: M's
Cost of coilover install...
Would like to know how much you spend on the install of your coilover system, and anything to watch out or replace...TIA
Live as if you will die tomorrow, but learn as if you will live forever." M.G
<img src=http://i251.photobucket.com/albums/gg289/l8dback/2012/ff8d7019.png border=0 alt= />
      03-27-2008, 02:45 AM   #2
pbdm4k
pbdm4k's Avatar
75
Drives: 2010 335d
$250 (for a coupe, roadster most likely more)
Check out Rogue Engineering for some rear shock mounts. This is beneficial that it replaces a weak part of the suspension and any subsequent mods to the rear suspension won't require you to tear up the trunk. It replaces the weak factory mounts with some nice billet pieces as well it converts the nuts to bottom mount instead of top mount.
http://www.rogueengineering.com/Merc...ategory_Code=S
And if you plan on slamming the car, you'll need adjustable control arms for the rear so you don't get excessive camber.
http://www.uucmotorwerks.com/CHROMOLY_ADJ_ARMS/
Front camber can also be taken care of as well:
http://www.uucmotorwerks.com/suspension/camber/
If you're not gonna bother with the other UUC mods (gets really pricey), I highly recommend at least doing the RE shock mounts. If you're putting in suspension this is one of those must do mods at the same time.
And thanks for posting where it belongs!
2010 BMW 335d "Ha! She wants the D."
2006 VW Jetta 2.5
Once upon a time...
'03 VW GTI, '99 Audi A4 1.8TQ, '00 VW Jetta 1.85T, '09 BMW 335i xDrive, '04 BMW Z4 3.0i, '01 Audi TT 1.8T, '04 Volvo S80 2.5T
      03-27-2008, 02:34 PM   #3
laidback
137
Drives: M's
Thanks...I will email RE and try to get those parts...
      03-27-2008, 03:23 PM   #4
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
Roadster will be substantially more, getting to the top strut bolts requires removing the soft top tray assembly, an additional 30 minutes possible per side.
      03-28-2008, 03:51 AM   #5
laidback
137
Drives: M's
thanks...I will be also upgrading to the adjustable rear lower arm...
      03-28-2008, 03:54 PM   #6
pbdm4k
pbdm4k's Avatar
75
Drives: 2010 335d
Are you going to go with the UUC arm? Or an eBay special?
2006 VW Jetta 2.5
Once upon a time...
      03-29-2008, 01:48 AM   #7
laidback
137
Drives: M's
I'm not sure yet...i'm still researching on which one to get...any recommendation?
      03-29-2008, 02:05 AM   #8
BimmerZealot
There's an eBay special? Up until tonight I thought there was only UUC for 350$
      03-29-2008, 03:33 AM   #9
BimmerZealot
I found SPC ones on eBay for about half the price of UUC but they dont look nearly as well built as the UUC ones.
      03-31-2008, 03:03 AM   #10
laidback
137
Drives: M's
Can you post the link...thanks
      03-31-2008, 12:45 PM   #11
BimmerZealot
Search Z4 Camber
      04-01-2008, 05:47 PM   #12
misterawa
John 14:6
misterawa's Avatar
Drives: Z4
If anyone's interested in a camber kit, Eibach makes one for a very reasonable price. Let me know, I know someone in LA that can sell you the part and install for < $300.
      04-04-2008, 02:32 PM   #13
pbdm4k
pbdm4k's Avatar
75
Drives: 2010 335d
Camber plates or Adjustable Control Arms?
Two very different things!
2006 VW Jetta 2.5
Once upon a time...
      04-04-2008, 02:33 PM   #14
pbdm4k
pbdm4k's Avatar
75
Drives: 2010 335d
Yeah, the UUC ones look really beautiful, but the cost is hard to justify.
2006 VW Jetta 2.5
Once upon a time...
      04-11-2008, 02:18 AM   #15
pbdm4k
pbdm4k's Avatar
75
Drives: 2010 335d
http://cgi.ebay.ca/BMW-E36-E46-Rear-...QQcmdZViewItem
Cosmo Racing aka el cheapo ebay version.
2006 VW Jetta 2.5
Once upon a time...
      07-07-2008, 11:51 AM   #16
Palantirion
Palantirion's Avatar
Drives: Z4 MC, M5, 540iT
GC's rear arms are great, and less expensive than UUC's: http://www.ground-control-store.com/.../II=655/CA=103
They also have rear shock mounts: http://www.ground-control-store.com/...php/II=8/CA=11
      07-09-2008, 12:41 AM   #17
Alpine M
Drives: Silver/Red Z4MC
You won't need the adjustable arms Chris ... I'm pretty sure I have the lowest Coupe I've seen yet and my alignment was perfect (Thanks to BMS!) with no extra additions.
I do however agree to get the Rogue rear mounts.
      07-21-2008, 01:21 PM   #18
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
You should look into the rear adjustable arms if you intend to use the car for track, unless you're prepared to buy a new set of tires every 3-4 events (or learn to drive conservative enough to not burn through the outside of the tires).
      07-21-2008, 01:28 PM   #19
Palantirion
-Rear bushing limiters are a must too, IMO. TMS and BMS both make them. They are cheap and easy to install. For those that don't know they limit lateral deflection of the rear control arm bushing without compromising its ability to compress vertically for bumps.
zpost
