ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      03-06-2008, 09:12 AM   #1
zuendi
zuendi's Avatar
Drives: Z4 Roadster 2.5i
Question staggered and non-staggered differents?
Hello all,
I have one question: can somebody explain to me what is the different between a staggered and a non-staggered wheel?
For example on some pages the CSL's replicas are offered like this.
However I can't see the different on the pictures.
Thank you in advance
Zuendi
Klaus
Best regards Klaus
Drive always safe
      03-06-2008, 09:51 AM   #2
BlackSapphireZ
Drives: 22 GLE 53 Coupe
hey you're here!!! glad you finally found this place
staggered means front wheel and rear wheel have different widths...little wider on the rear
non staggered means they are all same size all four sides
2022 GLE 53 Coupe
      03-06-2008, 09:59 AM   #3
zuendi
zuendi's Avatar
Hey Jin,
how are you doing?
Thank you for your explanation... now it's clear.
Hope to see you ones back here..........
Best regards
Zuendi
Best regards Klaus
Drive always safe
      03-06-2008, 04:05 PM   #4
david @ eas
david @ eas's Avatar
Drives: BMW
Originally Posted by zuendi View Post
Hello all,
Zuendi
Klaus
To answer your question in more detail, the Z4 M (Coupe and Roadster) the staggered comes in Weight:
19x8.5": 25.0lbs
19x9.5": 25.5lbs
Recommended Tire Size:
245/35-19 Front
275/30-19 Rear
and for the non M:
Weight:
19x8.5": 25.0lbs
19x9.5": 25.5lbs
235/40-19 Front
255/35-19 Rear
Check out the link to the wheels page:
http://www.europeanautosource.com/in...ath=67_203_205
zpost
