BMW M3 Forum (E90 E92)
      03-03-2008, 09:05 PM   #1
Gearhead999s
Gearhead999s's Avatar
817
Drives: RR Velar R=Dynamic M2C R1200GS
Stock Brakes for Trackdays
What pads are available to use for trackdays?What rotors are available that are non-drilled again to use with stock calpers.I have used drilled rotors and have nothing but problems with them with cracks probigating from the holes in the disc after only 2 hours of use on a relativly non demanding circuit.I have been told that only non drilled discs should be used for track duty.
      03-05-2008, 11:24 PM   #2
skierman64
skierman64's Avatar
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
BMW themselves are going to offer race compoud brakes. I'm not sure when they'll be available.
If you crack the stock rotors, they're under warranty. That's one good thing.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      03-06-2008, 07:31 AM   #3
Gearhead999s
817
I am not sure about the warranty on brakes in Canada.But what I was thinking was taking the stock brakes off and putting the "upgraded" rotors & pads on and when I go sell the car put the stock stuff back on.I only intend to keep this car for at the most a year and replace it with one with DCT,once I think they have it sorted out.I had drilled rotors on a c6 Vette and they would start cracking after very little track use and I do not want to repeat that.
      03-06-2008, 07:41 AM   #4
Gearhead999s
817
I just checked on the BMW Canada website and to have your pads & rotors covered you have to buy an upgraded service package.It was a good thought though!
      03-07-2008, 02:45 AM   #5
markjenz
Drives: m3 e92 mr
[QUOTE=skierman64;2257141]BMW themselves are going to offer race compoud brakes. I'm not sure when they'll be available.
BMW will offer race pads beginning of April 2008. You can order them via your Dealer. They work with the stock discs with full warranty.
The official Part no. will be:
front 2283764
rear 2283366
best regards,
Markus
"only if you can draw black lines from out of the corner until the next braking point you've got enough power" (Mark Donohue)
      03-07-2008, 07:38 AM   #6
Gearhead999s
817
[QUOTE=markjenz;2264820]
front 2283764
rear 2283366
best regards,
Markus
Thanks I will forward the part #'s to parts guy and see what he can come up with.This would be the easiest way to get some proper braking for the track.I have used the Motorsport pads before(Pagid?)with very good results.
      03-07-2008, 09:39 AM   #7
markjenz
Drives: m3 e92 mr
[QUOTE=Gearhead999s;2265166]
i used pagid yellow on my m3e46 and they worked very very well...only thing is they are not allowed on the street in germany...so now i hope the bmw's race pads can compete with pagid..
nurburgring is like going on a normal street..only quicker :-)
m3post
