New 2009 2010 BMW Z4 - ZPOST
      02-26-2016, 09:07 AM   #1
93Siro
Drives: Z4 35i
Battery is dead, how to open the trunk?
Installed a sound system. The capacitor is inline with the battery (mistake). Now the battery is dead, i cant open up the trunk. Due to the capacitor, neither i can jump start the car or charge the battery via the positive pole located up front. Is there any way to open up the trunk so i remove the damn capacitor?
Thanks
      02-26-2016, 09:40 AM   #2
Lurcher
Lurcher's Avatar
Drives: 2012 z4
Quick search will pull up a very recent discussion:
http://e89.zpost.com/forums/showthread.php?t=1019313
      02-26-2016, 11:10 AM   #3
93Siro
Drives: Z4 35i
Thanks but my god damned subwoofer box blocks the ski access fml lol
      03-02-2016, 07:46 AM   #4
bobmos
26
Drives: 2018 540i, 2015 Z4 35i
Run booster cables to the terminals under the hood. It won't start the car, but it will run the accessories including the trunk release button inside the car.
Cheers
      03-03-2016, 12:48 PM   #5
Desmo85
Desmo85's Avatar
83
Drives: E60 / E87 / E89
Cheers
I suppose if you dont have the trunk release button inside the cabin you may use the button on the Key Fob?
      03-03-2016, 01:03 PM   #6
talhagursoy
talhagursoy's Avatar
Drives: Bmw Z4 sDrive35i
Cheers
Isn't trunk release button standard in z4?
Ar Catless DP, MHD Flash, BMS DCI, ER FMIC, ER CP, Forged DVs
      03-03-2016, 01:59 PM   #7
sjeupie
Drives: Tiefseeblau E89 Sdrive 23i wit
Not in the EU models, neither is the emergency latch inside the trunk.
As mentioned previously, read the recent battery/trunk topic with all possible options: http://e89.zpost.com/forums/showthread.php?t=1019313
If your subwoofer blocks the ski-hatch/center storage compartment, you could force the trunk if it is not completely shut (as in that the electronic lock didn't engage and you still have an inch all around).
If your trunk is completely locked, you can't get trough the ski-hatch and you are 100% sure you cannot use the terminals under the hood, I'm afraid you'll have to call a BMW garage to dismantle the trunk. I'm afraid it won't be cheap.
      01-19-2019, 01:45 PM   #8
jollyo1956@gmail.com
Drives: 2009 BMW Z4
Disconnected battery and trunk locked 2009 Z4
I have a 2009 Z4 and I disconnected the battery. Inadvertently the trunk closed and locked (oh shit). Under the hood, there is a positive post used for jump starting the vehicle. I used a portable car starter connecting to the positive post and ground to the body and turned on the portable car starter. I then pushed the open trunk button and yes the trunk opened.
Appreciate 3
zpost
