09-02-2015, 01:38 PM | #1 |
223
Rep 542
dbronnik's e88 build (OEM 1M Front, VTT Stage 2+..)
Build thread for my dual duty autocross/street setup
Current Mods: Engine/Fueling/Exhaust: Built motor (built bottom end, rebello ported head, supertech valvetrain, CP pistons, manleey rods, schrick high lift cams,..) VTT Crankhub fix VAC Baffled Oil Pan ER Oil Cooler BMP Port Injection PR Dual 450 LPFP BPM4 LPFP Controller Motive Flex Fuel Box VTT Stage 2+ Hybrid Turbos (FRB coming soon!) VTT Inlets VTT Outlets Wagner Evo2 Competition Front Mount Intercooler Stett Charge Pipe & Tial BOV 3.5 Bar (N20) TMAP Sensor Burger Motor Sports Dual Cone Intake Burger Motor Sports Oil Catch Can Active Autowerke Downpipes MHD Custom Flash (v8bait) Suspension/Drivetrain: M3 Steering Rack (12.5:1 ratio vs stock 16.0:1!) M3 Rear Subframe Swap (entire rear axle) M3 Manual LSD/Differential (3.85) M3 Front Spindles/Hubs/etc TMS Solid Subframe Bushings Mason Engineering Strut Brace Ground Control Coilover Kit (Custom Valved Konis + 500#/700# Springs) Ground Control Camber Plates (Hybrid Race/Street: CCPE9XH) Custom Fabricated Rear Spring Perches (non-adjustable) H&R Front Sway Bar (27mm) H&R Rear Sway Bar (20mm) Brakes: OEM M3 Rotors/Pads Front & Rear SS Brake Lines Wheels/Tires: Apex EC-7 F - 18x9.5 ET22 R - 18x9.5 ET45 (note: these only fit due to subframe swap) Bridgestone Potenza RE-71R F - 275/35/18 R - 275/35/18 Exterior/Interior/Electrical/Miscellaneous: OEM BMW Performance Electronic Steering Wheel v2 OEM BMW M3 DCT Paddles OEM BMW Piano Black Grill OEM 1M Front Conversion OEM 1M Mirrors Revozport Carbon Fiber Hood (wrapped black) LUX H8 V5 Color Adjustable Angel Eyes Android HU xHP Stage 3 Flash
09-02-2015, 02:33 PM | #3 |
89
Rep 527
NSFW, Your car is naked!
09-02-2015, 02:45 PM | #4 |
all day
48
Rep 1,181
Drives: 2012 135i
Good progress!! Cant wait to see whats up
But wait, no upgrade to your FMIC? And what tires were your running in that track pic? |
09-02-2015, 03:36 PM | #5 | |
223
Rep 542
FMIC is definitely at the top of my future upgrades. I'm pretty sure that picture was from when I was running Continental ExtremeContact DW (225 front 245 rear), but I can't say for sure.
09-02-2015, 04:24 PM | #6 |
1337
Rep 2,095
Drives: '11 135i M Sport
Nice a 1M conversion Vert! Now thats different! I think there is only 1 other 1M converted vert out there.
09-02-2015, 10:16 PM | #8 |
89
Rep 527
Is there any discernible difference in feel of the 1m front strut bar vs the mason engineering?
09-02-2015, 10:57 PM | #9 |
223
Rep 542
Huge difference -- not sure how to describe it but the front end feels much more solid with the Mason Engineering bar. The only gripe I had with it was that I had to get a shop to machine it to get it to fit, but even so was well worth the money
09-02-2015, 11:55 PM | #10 |
89
Rep 527
Did you get the one with the the stock arms or the short custom arms? And what did they have to adjust, machine? I have been drooling over that piece for a while
09-03-2015, 12:08 AM | #11 | |
223
Rep 542
edit: here's a picture, you can see how the cutout was a little bit off and had to be machined out a little to fit. Last edited by dbronnik; 09-03-2015 at 01:28 PM.. |
09-03-2015, 03:08 PM | #12 |
Joint Chiefs of Staff
24415
Rep 191,323
Looks good !!
That being said i would get that charge pipe soon
09-03-2015, 04:08 PM | #13 | |
89
Rep 527
09-03-2015, 04:36 PM | #15 |
827
Rep 3,856
Can't wait to see this, what a build
09-04-2015, 01:42 PM | #17 |
223
Rep 542
I'm located in norcal / bay area
Here's a teaser pic -- still need to finish up a couple things under the bumper (you can see air ducts aren't installed), but I got impatient waiting for last of parts to show up so I threw it on there
09-04-2015, 05:03 PM | #18 | |
89
Rep 527
What is your side skirt solution? |
09-04-2015, 06:18 PM | #19 |
223
Rep 542
Thanks! I haven't decided on the side skirts. I'm still running the 135i side skirts right now so they're not lined up in the front. It's not that bad -- actually it's sort of annoying that the fender LINER pokes out..
I discussed a couple options with the shop I went to to get my parts painted and they said they were confident they could mold the two side skirts together, but not confident they could pull the side skirts out to somewhat line up with the fender using a heat gun (I would have preferred that approach). I'm still considering both options, but realistically I'll probably just wait until I do the rear end conversion
10-05-2015, 10:06 PM | #20 |
Resident Kerbalnaut
478
Rep 10,703
Living my dream man! Looks fantastic. Can't wait to see how it drives with the turbos.
Have you thought about inlets? They're much easier to do with the turbos out and show a number of improvements in flow and turbo response. Last edited by BrokenVert; 10-05-2015 at 10:23 PM.. |
10-05-2015, 10:41 PM | #21 | |
223
Rep 542
I have my eye on the TFT inlet system, but it's just a little too much all at once for now
10-06-2015, 07:45 AM | #22 | |
Resident Kerbalnaut
478
Rep 10,703
Though TFTs are an interesting move, those are the ones that relocate the filters to the left side of the motor, right? |
