07-14-2015, 03:32 AM | #1 |
E92 M3
99
Rep 508
Drives: (2) E92 M3's & F30 320i
Add 1 Quart of oil or change oil completely?
Hey guys, so I haven't had to change my oil in a while because I don't drive the car too often. But I just got the +1 Quart warning light on the dash. Should I add 1 quart or change the oil completely? Its a pretty basic question but would like some input so I don't waste money.
07-14-2015, 04:54 AM | #2 |
303
Rep 1,140
Drives: Something something racecar
Define "a while." If it's been a year or more, change the oil. If not, just add oil.
07-14-2015, 06:56 AM | #3 | |
594
Rep 4,488
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
07-14-2015, 09:54 AM | #4 |
Rep 1,197
Drives: 2021 F87 M2c. LBB, 6mt
Curious, whats the logic behind changing the oil after a year if it doesn't have a lot of miles on it?
2021 F87 M2c. Long Beach Blue over black with blue stitching. 6mt, executive package, slick top.
07-14-2015, 10:03 AM | #5 |
4987
Rep 11,891
What's your annual mileage and when was the last oil change?
Please tell me you know these answers
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
07-14-2015, 10:21 AM | #6 |
Rep 198
Personally I add until it is time to change. If I drive enough before it is time to change the oil I just continue to add what is needed.
Almost seems like it would have fresh oil all the time if you are just constantly adding, but then if you are doing that you may have an issue. |
07-14-2015, 10:21 AM | #7 |
HMFIC
372
Rep 522
Drives: 2016 F80 M3
07-14-2015, 11:02 AM | #8 |
Rep 1,197
Right, i get the recommendation for the first part, but I just have a hard time buying into the oil is bad after one year theory. But, then again, I don't know that much about oil and I drive enough where time is not the issue.
07-14-2015, 11:14 AM | #9 |
4-6-8
234
Rep 990
I believe thats what it says in the manual too, change every year.
M3 E46 PY/Black
S2000 AP2 GPW/Tan |
07-14-2015, 11:25 AM | #10 | |
275
Rep 529
OP- I'd suggest simply adding a qt of oil rather than changing it. However if you're at like 9k miles since the last oil change, you might as well just go change your oil.
Instagram: That_M_Power
E93 M3 AC Schnitzer Carbon Fiber - Fully Gutted Exhaust and muffler delete | 2007 DB9 Bone Stock | 2016 428i |
07-14-2015, 11:37 AM | #11 |
Sporty Puristic 6
46
Rep 384
Regardless of if it's time to change or not, you shouldn't run the car a quart low.
I guess you could immediately change oil. But in the meantime if you're driving the car, top it off. |
07-14-2015, 11:41 AM | #13 | |
4846
Rep 2,445
Drives: 2022 M3 6MT
However, if oil is in it's sealed bottle on your garage shelf, then you should be fine, provided the temperature isn't to extreme.
2022 M3 6MT - Portimao Blue Metallic
2022 X3 M40i - Tanzanite Blue Metallic |
07-14-2015, 12:02 PM | #14 |
377
Rep 2,982
Am I missing something? Your car is a 2013 isn't it?
You should have had an oil change at 1500-2000 miles, then another one every 10k miles or every 12 months. Whichever comes first. And if your car is a 2013 those minimum 1/yr oil changes are covered. So if it hasn't been a year yet, top it off. I have my second annual oil change happening tomorrow at the dealer and my car asked for a qt three days ago so I just burned a qt even tho it's all going in the drain anyway so soon. |
07-14-2015, 12:30 PM | #15 | |
275
Rep 529
07-14-2015, 12:39 PM | #16 |
E92 M3
99
Rep 508
My bad, I've been working all morning.
The last time I had a full oil change/filter change was about 10k miles ago.. and it is just giving me the +1 quart warning sign. I drive about 40 miles a day/4-5 days a week all highway and the temperatures outside vary from 58 degrees to about 75 degrees.. (I know temps play a roll on how fast oil is eaten up) |
07-14-2015, 12:40 PM | #17 |
E92 M3
99
Rep 508
Thanks! Ill just stick to adding a quart then and hopefully my engine doesn't blow up..
07-14-2015, 01:07 PM | #18 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
Re: The 12 month oil change
I'm betting that even Blackstone could not tell the difference between a synthetic oil that was in the engine for 12 months versus oil that was left in service for 16 months, given the same number of miles (in the same engine). At least for me-- the car is stored inside an insulated garage, dry climate, never driven in rain, etc. That, and not taking a bunch of short drives where the car doesn't warm up, keeps moisture from building up in the oil. While 12 month oil change intervals couldn't hurt, going a while longer on a weekend car that sits in the garage all week doesn't matter at all. If the car is a daily driven "grocery getter", by all means, do the 12 month oil service. My M3 gets less than 4k miles per year, like a lot of others I've seen, and those are the ones that could get by with longer than 12 months. Last edited by Beemdog; 07-14-2015 at 01:12 PM.. |
07-14-2015, 01:09 PM | #19 | |
Rep 817
Drives: 2013 E92 M3
07-14-2015, 03:44 PM | #20 | |
Rep 1,197
07-14-2015, 04:29 PM | #21 | |
275
Rep 529
07-14-2015, 04:49 PM | #22 | |
4987
Rep 11,891
So my answer to your question is: Do Both, add oil now and change your oil. But as others have said, until you can change it, add 1/2 bottle to maintain proper level. Last edited by Flying Ace; 07-14-2015 at 05:07 PM.. |
Tags |
competition package, e92 m3, oil, zcp |
