02-21-2015, 08:28 PM | #1 |
901
Rep 3,071
Can BMWhat program default M mode on?
Now that the S65 is supported is this an available option to code so I do not have to press the bleeding button every time?
Previous BMW: 16 M4, 13 M6; 14 M235i, 12 BMW M3; 11 BMW M3; 08 BMW M3; 08 BMW Z4M; 04 X3; 02 M3 Convertible; 02 M3; 00 M Roadster; 94 325 convertible; 92 325i Convertible; and 85 635csi
My Car Photo Blog: http://carfisheye.blogspot.com/ |
02-22-2015, 01:16 AM | #3 |
727
Rep 1,974
LOL never thought this would be a problem. I would assume you can get that coded in but you can at least set the car to start with the power button on. You can set that in M settings and push the idrive to the right.
2013 BMW E92 ///M3 AW/BLK ZCP CF Roof 6 Speed - Perfection
2011 BMW E90 328i xDrive Space Grey/Black - Daily 2011 BMW E93 ///M3 MW/FR/BLK 6 Speed - Gone but not forgotten |
02-22-2015, 06:57 AM | #5 |
901
Rep 3,071
Thanks Stook.
and bavarian beast, thanks for pointing out the obvious.
02-22-2015, 07:18 AM | #7 |
4488
Rep 7,131
02-22-2015, 08:09 AM | #8 | |
594
Rep 4,488
OP, my gut says that defaulting M Drive to on would be a DME change, not a coding change.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
02-22-2015, 01:33 PM | #9 |
262
Rep 1,616
You should be able to set any of the options as the default. You should also be able to access all of the options a la carte and not have to switch on M mode before being able to get to them.
02-22-2015, 07:37 PM | #10 |
901
Rep 3,071
"You should be able to set any of the options as the default. You should also be able to access all of the options a la carte and not have to switch on M mode before being able to get to them."
are you saying BMWhat does this or are you speculating?
02-22-2015, 11:37 PM | #11 |
Rep 657
i've scanned the thread in the coding section, but i still can really determine what i would do with this app. Anything worthwhile, other than the number of seconds my interior lights stay on after i turn off the key?
02-23-2015, 01:28 AM | #12 | |
262
Rep 1,616
02-23-2015, 02:07 AM | #13 |
4488
Rep 7,131
A few I like is have window continuing closing even after opening door (maybe local "safety" coding which is quite annoying), increase angle eye brightness, setting digital speedometer true speed (analoge meter possible as well). Have a few more currently but can't remember them now.
02-23-2015, 07:17 AM | #14 |
901
Rep 3,071
Agreed dreamspeed, agreed
02-23-2015, 10:24 AM | #15 |
Rep 56
The only things "locked" to the M mode is MDM and sports plus throttle (useful on highway only).
I don't know about first world problems, but this seems a silly thing to do. Why do you want your car in balls-out mode the moment you start it cold? The baby mode is a good way to keep yourself from pushing it until the oil is up to temp. And seriously, it's so hard to press the one button? I assume you have DCT and only run it in D. Last edited by knevel; 02-23-2015 at 01:12 PM.. |
02-23-2015, 10:33 AM | #16 |
Sporty Puristic 6
46
Rep 384
I was under the impression that you could make all typical M-mode settings as default in the idrive. I'll have to take a look at that again.
Personally I drive with sport steering as default, but prefer to save MDM mode, most aggressive gearchange and power setting for the M button. Now if you want the little "M" light to shine all the time, that would probably take some doing. |
02-23-2015, 10:35 AM | #17 |
Sporty Puristic 6
46
Rep 384
02-23-2015, 01:06 PM | #18 |
Too many wagons on the bahn.....
98
Rep 582
Got it haters. Didn't mean to piss you all off. Guess I should have put a smiley face on it since it was just a joke. Now don't hurt your finger pushing that hard old M button. Out.....
02-23-2015, 02:26 PM | #20 | |
594
Rep 4,488
02-23-2015, 04:32 PM | #21 |
Rep 244
02-24-2015, 06:17 AM | #22 |
901
Rep 3,071
"The only things "locked" to the M mode is MDM and sports plus throttle (useful on highway only)." Wrong
"I don't know about first world problems, but this seems a silly thing to do." Sure, BMW adds silly features, says so right in the Owners manual M Mode is a silly feature "Why do you want your car in balls-out mode the moment you start it cold?" Please don't confuse being in the balls out mode and driving in balls out mode. Just not the same "The baby mode is a good way to keep yourself from pushing it until the oil is up to temp." Being adult I also can wait to push it until the oil is up. Also since you think the M button is silly, that means you do not use it and you drive around in baby mode at all times. "And seriously, it's so hard to press the one button?" No, but is is so wrong to want the car to be the way you want it at all times too much to ask? Yu must get up and change teh channel on yor balck and white non-cable TV being the I refuse to have it my way person. "I assume you have DCT and only run it in D." You assume wrong. Why would I want M mode s5 all the time and drive in D.
