01-24-2015, 11:21 AM | #1 |
Rep 307
Drives: 11' E82 S65 1M, 21' F95 X5MC
1LittleMonster 135i > 1M Build (#1littlemonster)
Featured on BIMMERPOST.com Recaro Sportster CS Heated Black Leather Seats Macht Schnell Seat Mounts & Recaro Sliders VAC Custom Bolt-In Roll Cage VAC Wheel Spacers (Rear Only - 15mm) Sprint Booster BMW PPK2 - Performance Power Kit 2 - (high output cooling fan, secondary radiator) Cobb Catted DP Meisterschaft GTHAUS 1M SS Exhaust Agency Power FMIC BMS Charge Pipe BMS Modified BMW Clutch Valve BMS Oil Catch Can aFe Stage 2 Magnum Force Cold Air Intake aFe Dynamic Air Scoops M3 Front and Rear Sway Bars M3 Rear Subframe, Differential, & Suspension Components 1M Drive Shaft 1M Strut Mount Brace AirLift Performance 3H Management AirLift Performance Air Bags & Fully Adjustable Dampers Accuair trunk decklid mounted 5 gallon air tank BMW Performance Blackout Grille Hankook Ventus RS3 265/35ZR18 APEX ARC-8 18x10 ET22 Square APEX Race Wheel Stud Conversion BMS Amber Angel Eyes Vorsteiner Rear Carbon Diffuser Revozport 1M Front Splitter Revozport 1M Trunk Lip Spoiler Revozport Single-Sided Carbon Hood iND Painted Side Markers 1M Gauge Cluster Xpel Protective Coating - Full Kit Custom coding & features from NTX (01.03.2016 update) Last edited by Brearley_III; 06-13-2017 at 10:15 AM.. Reason: 6/13/2017 update |
01-24-2015, 11:31 AM | #3 | |
Rep 307
If anyone can recommend a body shop on the East Coast I would make as long of a drive as I need to have it done perfectly!
'87 E30 M62 V8 6MT -- '11 E82 1M CLONE S65 6MT -- '21 F95 X5MC |
01-29-2015, 09:09 AM | #5 |
Rep 307
I have parts on the way!
ECS Tuning; OE BMW 1M parts needed for exhaust & battery re-location AutoCouture Motoring; Meisterschaft SUS Super GT Exhaust * They will also be coding my Braille Battery & doing a valve cleaning, check these guys out! http://autocouturemotoring.com/ Amazon.com; Braille B3121 Lightweight Battery & 1232 Charging Solution EAS: Macht Schnell - Aluminum Lightweight Battery Enclosure And the GRAND FINALE! Revozport - Lightweight Bonnet w/ Aerocatch & Interior Carbon Trim Kit
01-29-2015, 10:07 AM | #6 |
Rep 615
Drives: BMW 120d e82 M Sportpaket
I will follow this thread, maybe I will have some new ideas for my build
M Sport package, Stage 1, CDV, BMC airfilter, VMR vb3, ST XTA, BMW Performance stuff, M3 arms, E93 M3 anti-roll bars F and R, ... French community of 1 and 2 Series: One-Two-Bimmers |
01-29-2015, 03:18 PM | #8 |
Rep 307
Thanks! Yours definitely came out amazing!
01-29-2015, 09:23 PM | #9 |
Rep 1,264
I can't wait to see the progress...
750whp 135i Build | Budget 335i Build | F80 M3 Build
🎬 YouTube channel (35K+ subs): youtube.com/jakespence135 📷 Follow me on Instagram: instagram.com/jakespence 🏁 Shop BMW merchandise: bimmerstreet.com |
01-30-2015, 02:59 PM | #10 |
Rep 307
update;
Huge THANK YOU for Status / Agency Power for Sponsoring this project!! Should be seeing 2 of these beauties in 3-4 weeks! Status Ring FIA Approved And this!
01-30-2015, 03:39 PM | #12 |
1518
Rep 4,744
Drives: S65 1M Clone & E92 M3 4.6L
awesome. cant wait to see this come together!
01-30-2015, 04:43 PM | #13 | |
Rep 307
I ordered a Braille battery so I'll let you know how I like it! I will get that installed and coded 1st before the relocation... Then Ilikebmxbikes confirmed that the old 135i bumper will work with the 1M carrier... I will just remove the diffuser so I can run the quad exhaust while I wait for the rest of the parts to arrive...
01-30-2015, 08:03 PM | #14 |
Rep 1,181
LittleMonster_III > Are you changing the battery bucket and the whole 9-yards? Also, when i restructured the build and broke it down into different pages, I forgot to add the PPK2 section. Just haven't had time. If you're doing that as well, let me know.
02-03-2015, 02:00 PM | #15 |
Rep 307
I am! I saw your thread too... Almost ordered the wrong negative cable too! Thanks for the amazing work on that btw! Got the battery today too! I'll post pics later tonight...
02-04-2015, 09:49 AM | #16 |
Rep 307
Braille has arrived!
02-04-2015, 02:21 PM | #18 |
Rep 307
hmmm... you're right. I will check that tonight when I get home.
02-04-2015, 03:09 PM | #19 |
Rep 1,181
LittleMonster_III > I can double check and give you the height of my battery for comparison. You also have to account for the distribution box that goes on top -- bumps it up a little more.
In terms of length (assuming you're doing the 1M tray), it has to be under 11" for the floor-nut to be exposed -- this is where the battery-holder screws into. |
02-04-2015, 03:10 PM | #20 |
Rep 1,181
I also noticed the Braille doesn't have an edge/lip along the bottom. Not sure the stock holder will work if that's the case. Did it come with it's own holder?
02-07-2015, 11:51 PM | #21 |
376
Rep 2,388
Drives: M2 Competition
You should bug Sk8fe He may have finished the rear quarters?
Good Luck! I hope you know what you are getting yourself into |
02-09-2015, 05:52 AM | #22 |
Rep 307
TUN3D; I bought the Macht Schnell battery hold down for the 1M holder, ilikebmxbikes build had that info for me so I knew it would work.
Venom; Thanks! I'll definitely PM him. Still trying to find a body shop too so that'll help!
Tags |
1m build, 1m conversion, hankook, quad exhaust, revozport |
