ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Cosmetics Modification (Exterior/Interior) Discussions
  TireRack
      01-15-2008, 03:32 PM   #1
cabear
Drives: 03 Z4 2.5i
Stock xenon question- one headlight brighter then the other?
for some reason my driver side light seems brighter then the passenger side. i have the stock xenon set up with auto levels and wonder if i should get it adjusted or is it normal beam pattern?
thanks!
      01-16-2008, 01:22 PM   #2
em2b96p
Drives: cbr600rr
the right should be brighter (aka aimed higher). you can adjust them yourselves with an allen wrench. there is a white "knob" behind the headlight.
there is also a DIY tutorial on proper headlight aim link
http://www.danielsternlighting.com/images/Aim.pdf
zpost
