01-03-2015, 07:09 PM | #1 |
1099
Rep 2,286
Today I went out for a little drive... Not much slush on the roads this afternoon in my area - mostly water (either because temps slightly above freezing and salt on roads). Given these conditions, I keep DSC fully on.
So on straight stretches of road with little water and DSC on, I tried giving a good amount of throttle from about 2k-4k rpm, and then doing the same in 3rd gear (1st gear under such conditions will obviously cause DSC to intervene quickly and cut engine power at the slightest hint of wheelspin - so I didn't even try this in 1st). I noticed a BIG difference in how much DSC cuts power in 2nd gear under such conditions vs. 3rd gear - I understand that torque multiplication is going to apply to differences in the gear ratios, but I didn't realize that: 2nd gear pulls at about 50-70% throttle from 2k-about 4-5k rpm gives some wheelspin and cutting of engine power with decent acceleration. HOWEVER - same thing in 3rd gear - HOLY CRAP!!!! Even with full DSC on, throttle set at efficient and drivelogic set at S2 - borderline savage acceleration with little or no wheelspin!! (Let me clarify though - since 3rd gear is going to have much higher speeds for a given rpm vs. 2nd gear - the "bursts" of acceleration in 3rd gear obviously couldn't last as long. Just curious if anyone else has noticed such a difference in how the ECU cuts power to a far greater extent in 2nd vs. 3rd gear - I always suspected there was some difference - just nowhere near to the extent I discovered today... |
01-04-2015, 07:20 PM | #2 |
High on Acceleration
671
Rep 1,439
Yes, I've noticed the same thing. The acceleration in lower gears with the traction nannies on is severely compromised and also very inconsistent. When I drove the car on the Nurburging I liked how it would save my bacon but on the streets I'm constantly left wondering where my power is. I guess they have made the car much can safer for novice drivers not used to so much power.
01-04-2015, 07:44 PM | #3 |
Moderator
618
Rep 10,858
I sense a difference from my Euro driving. I wonder if the USA programming interferes more than the set up for ED.
My recent ED photos: http://f80.bimmerpost.com/forums/sho....php?t=1026808
my not-so-recent ED: http://www.e90post.com/forums/showthread.php?t=31829 Please join BMWCCA http://bmwcca.org/index.php?pageid=c...&ref_by=300279 |
01-04-2015, 07:50 PM | #4 |
Rep 41
I feel the same, but also think it may just be my head playing games with me.
I find myself totally disabling DSC in order to do anything remotely interesting (including accelerate quickly in a straight line below 60mph) which is sub-optimal. MDM is useless as well unless the conditions are perfect (warm tires, 70out and dry), in which case it seems to let an agreeable amount of wiggle happen. I remember driving aggressively up and down many mountain passes to include Furka and many autobahn runs on ED during which I never went beyond MDM without the same complications... again it could just be my warm memories of the new toy |
01-04-2015, 08:06 PM | #5 | |
Rep 971
01-04-2015, 08:47 PM | #6 |
5459
Rep 7,037
My right foot + DSC does a fine job in putting down power ( not to be confused with ALL power ) in all gears, I still don't get these complaints. Good for me I guess, I.e I don't want to understand
01-04-2015, 08:51 PM | #7 |
671
Rep 1,439
Yeah, it does what it is supposed to do. The issue is how much power is it cutting to do its job? And how does it go about doing so with seemingly bizarre inconsistency?
01-04-2015, 08:59 PM | #8 |
5459
Rep 7,037
Mine doesn't seem to cut power until I got slippage but I tend to roll on the power and also not slam into the gears ( I have MT ) so if it cuts power when it detects sudden extreme drive train stress without slippage as well I wouldn't know since I try to avoid that.
01-04-2015, 09:02 PM | #9 | |
Rep 971
01-04-2015, 09:07 PM | #10 |
5459
Rep 7,037
No way an X5 35i can hang with an M3 with DSC on beyond first gear. I'm starting to wonder if the DSC programming has been changed at some stage? Mine is a July build.
01-04-2015, 09:11 PM | #11 | |
671
Rep 1,439
01-04-2015, 09:13 PM | #12 |
Rep 302
Drives: 2017 i8 coupe
Garage List 2014 Ferrari 458 Sp ... [10.00]
2013 Toyota Tacoma [0.00] 2015 BMW 228i [0.00] 2015 M4 Convertable [10.00] |
Fascinating discussion: I wonder if this is simply a reflection of the huge amount of torque this engine develops very low in the rev range. In second gear when accelerating hard even on the bone dry roads where I live the torque is stunning and I am still tying to keep within 55000 revs/110 during my break in period. The car really wants to shimmy and I think the tires struggle to hold traction. If it was not for DSC in 2nd gear I think a lot of us might end up parking our cars into the guard rail. Once in 3rd I think the car has established balance and grip and DST does not need to intervene (Unless you really overdo it) Maybe I'm misunderstanding your point but I'm trying to say I think DSC is doing its job correctly..
"AY Brave!"
01-04-2015, 09:21 PM | #13 | |
Rep 302
I suspect a lot of high Torque cars have issues getting the power down at first. Maybe the rear tires on the M3/M4 are not up to the job?
"AY Brave!"
01-04-2015, 09:25 PM | #14 | |
Rep 971
Well of course. I mean from a 25MPH roll there's very little in my town that can hang with the M3. From a dig the thing is doing stupid stuff to the power. |
01-04-2015, 09:25 PM | #15 | |
5459
Rep 7,037
Just practice rolling on the power if you have problems with it. |
01-04-2015, 10:21 PM | #16 | |
Rep 302
"AY Brave!"
