ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      12-09-2014, 10:42 PM   #1
tooch
Drives: F82
Suspension install DIY
I was wondering if there was a diy for the suspension on the M4. Got my V3s and wanna install them soon. I lowered my E92 so its probably not that different, I still like something to rely on for reference. thanks for any help.
96 E31 JB
07 E92 AW
F82 BSM
      12-09-2014, 11:26 PM   #2
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Need some help with that?
      12-11-2014, 04:41 PM   #3
tooch
Drives: F82
I'm always down for some help. Probably won't put them on until January sometime maybe feb. if I can hold out that long. I'm really looking forward to a nice drop on this car.
96 E31 JB
07 E92 AW
F82 BSM
      12-11-2014, 04:49 PM   #4
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Anytime as long as it's the weekend I can definitely help out.
      12-20-2014, 10:30 AM   #5
NorCal f80
346
Drives: M3
The front is tedious to do because of the strut bar and whatever else blocks the top hat bolts on top ---- plastic, trim, rubber, etc. The rear is too easy and could be done in 15 minutes if someone were in a hurry.
SIDE NOTE FOR KW V3, maybe for KW HAS too, as it looks similar: For the front the lowest you can probably go on stock wheels without spacers or aftermarket wheels is ---- perch adjusted showing ~1.25" of thread. Any lower and the spring will rub on the inner tire. At this adjustment it will put the fender at the tire or maybe even a tiny little tuck of the tire.
      12-21-2014, 06:12 PM   #6
MasterC17
Drives: 2015 BMW M3
See my DIY here, http://f80.bimmerpost.com/forums/sho....php?t=1071406
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
      12-22-2014, 11:12 PM   #7
tooch
Drives: F82
Did you have to remove the whole trunk interior kit for the rear? I've never ran spacers before, what size would I need to run if I choose the route? Thanks
96 E31 JB
07 E92 AW
F82 BSM
      12-22-2014, 11:19 PM   #8
Wei718
Wei718's Avatar
340
Drives: 718 GT4
It looks like the rear is all done from under the rear wheel well now. No more removing interior parts.
      12-23-2014, 10:28 AM   #9
NorCal f80
346
Drives: M3
Nope, and that's one reason someone could do the rear in 15 minutes. Bolts are accessible from outside the car. Once you take the wheel off you'll see 3 bolt up top. I'm guessing 15mm would be perfect. Look for the thread with a blue M4 lowered pretty low, I think he is on 15mm.
      12-23-2014, 11:42 AM   #10
MasterC17
Drives: 2015 BMW M3
Rear doesn't require trunk access, I have 15mm spacers all around with KW HAS at lowest setting.
      12-25-2014, 03:06 PM   #11
tooch
Drives: F82
I checked out your build thread I was wondering if you had any bright light photos of looking down the side of the car. Kinda wanna see how far 15mm will push the wheel out. Thanks
96 E31 JB
07 E92 AW
F82 BSM
      12-27-2014, 09:25 PM   #12
tooch
Drives: F82
I saw that today when I was getting a screw taken out of the rear tire... Thats awesome, so easy. Thats good cuz I hate taking the interior outta the the trunk, never goes back perfectly.
96 E31 JB
07 E92 AW
F82 BSM
      12-27-2014, 10:24 PM   #13
Wei718
Wei718's Avatar
340
Drives: 718 GT4
It's bad if the KW V3 compression adjustment is still on the top of the coil though which means you would need to remove the shock in order to adjust that. You have any pic's of the rear shocks on the KW's?
      12-27-2014, 10:42 PM   #14
NorCal f80
346
Drives: M3
Here is the bottom and it may be the bump adjustment. I'd have to remove the wheel to check the top.
      12-27-2014, 11:15 PM   #15
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Yeah, that is the bump adjustment. Let's hope the rebound adjustment is accessible without removing the shock.
      12-27-2014, 11:26 PM   #16
NorCal f80
346
Drives: M3
I think it is accessible just like the bottom.
      12-28-2014, 11:47 AM   #17
tooch
Drives: F82
Heres the front and the back, I don't know what the stocks are. hope this helps, Lemme know what u find out vs the stocks.
96 E31 JB
07 E92 AW
F82 BSM
      12-28-2014, 11:57 AM   #18
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Awesome! Looks like the rebound valves are on the top sides which means you don't ever have to drop the shocks to adjust those and can be done by jacking up the car.
      12-28-2014, 11:58 AM   #19
tooch
Drives: F82
Correct, should be somewhat simple. A few guys on here said they were happy with the set-up right outta the box.
96 E31 JB
07 E92 AW
F82 BSM
      12-28-2014, 12:06 PM   #20
Wei718
Wei718's Avatar
340
Drives: 718 GT4
We need to meet up again after you get them installed. The passive suspension is so harsh in the city perhaps those coils are the answer lol.
      12-28-2014, 12:08 PM   #21
tooch
Drives: F82
Where should I get my spacers from? I'm gonna get them beforehand just in case I need them. Thinking of going just 10mm. Will that be enough to clear the coil over? does this only come into effect at the lowest setting? I probably won't ever be at the lowest setting
96 E31 JB
07 E92 AW
F82 BSM
      12-28-2014, 12:09 PM   #22
tooch
Drives: F82
Theres no way the KW will be rougher than our passive, my car already bounces around like it would with an extreme drop. Mines pretty rough also
96 E31 JB
07 E92 AW
F82 BSM
f80post
