      08-17-2014, 05:01 AM   #1
BMWhoarder
Resisting mods
Australia
48
Drives: 135i
JB4 - Dyno results
just wanted to share my dyno results from the other week.
Car is completely stock (n54) with a JB4, was running on map 5 with a 50/50 mix of e85/ BP 98 at the time.
Pretty happy with the result. I did unfortunately hit a cut just after 5k rpm on my earlier runs so not sure if there was anything left it in. Have since put the backend flash on which apparently should help. Not going to get back on the dyno for a while though.
Next mods are and inline 255 to help handle the e85, followed by (probably) a bastuck quad exhaust. will see what funds i have left in the kitty after the house is finished.
      08-17-2014, 08:22 AM   #2
bsm135
bsm135's Avatar
23
Drives: Bmw 135i
Nice result.
Happen to do a baseline run on map 0?
      08-18-2014, 02:04 AM   #3
racer_x
racer_x's Avatar
13
Drives: When He Has To
Excellent result. What are you doing about cooling?
      08-18-2014, 04:59 AM   #4
BMWRX
BMWRX's Avatar
Australia
99
Drives: F82 M4 CP
2017 BMW M4  [0.00]
That's seems a bit high for a stock car with only JB4
2017 BMW M4 Competition - Mineral Grey
2009 BMW 135i - Titan Silver - SOLD
      08-18-2014, 05:40 AM   #5
flinchy
127
Drives: E82 135i
running a lot of boost though
      08-18-2014, 07:12 AM   #6
froop
froop's Avatar
Australia
171
Drives: 08 AW 6MT E82
Our E88 managed 263kW on map 5 with E40 and only DCIs. Definitely doable but only good for about 1 run before the heat soak.
      08-19-2014, 12:08 AM   #7
BMWhoarder
Resisting mods
Australia
48
Drives: 135i
Currently? Nothing. Given i live in Canberra and we see a maximum of 14 degrees for a significant portion of the year, IATs aren't too bad.
Might look into a bigger FMIC down the track, but i'm also not planning on doing much more to the car after the listed mods, given it's my daily driver and i'm more focused on directing my funds towards the house now.
      08-20-2014, 10:33 PM   #8
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
812
Drives: a black car
Good result. Would've been a nicer graph and log if done in fourth gear.
      08-22-2014, 01:58 AM   #9
BMWhoarder
Resisting mods
Australia
48
Drives: 135i
the run was done in 4th
1addicts
