08-12-2014, 11:32 PM | #1 |
Facetious
109
Rep 530
Start / Stop function with 6sp
For some reason I can't seem to get the car to shut off when I turn on the start/stop function. Does it stop in gear, with clutch and brake in, or does it have to be in neutral, with only the brake depressed? I tried both and it seem to work.
Current: '15 BMW M4 (6MT), '08 HD Dyna Street Bob
Previous: '06 BMW 330Ci; '06 Mercedes CLK-350; '04 Acura TL A-Spec; '95 BMW 318ti; '92 Mercury Cougar; '94 Honda Accord |
08-13-2014, 06:01 AM | #2 |
Rep 35
On my car only seems to work if in neutral, brake only. Pushing in the clutch or moving the steering wheel start the car. Also the switch is opposite of what you might think. The light on means start/stop is off. When the light is off the system is active.
08-13-2014, 06:17 AM | #3 |
Rep 189
It only stops when it's in neutral *and* you release the clutch. The engine also needs to be warm. There may be some other prerequisites as well. I've found this to work very well because you don't shift to neutral when you anticipate short stops and hence the engine keeps running. When you anticipate longer stops it is natural to shift into neutral
08-13-2014, 08:23 AM | #4 |
555
Rep 2,633
On the e90 the car would only stop if conditions where ideal. If it was to hot out it wouldn't start/stop. Would make sense if it was the same on f80.
08-13-2014, 08:41 AM | #5 |
Rep 165
Drives: F82 M4 moonstone
the manual describes quite clearly what parameters are required (or at least you'll find plenty of information in the tech.spec. document in another (sticky) thread).
08-13-2014, 09:12 AM | #6 |
Bored all the time
382
Rep 2,173
Why would you want this feature on an M car? I never understood that.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3... It all started with an RX-7 (FD). |
08-13-2014, 09:24 AM | #7 |
Rep 165
08-13-2014, 09:56 AM | #8 | |
Rep 253
Mine stops what seems to be at pretty inconsistent times but it does have to be neutral brake only. For examples stop and go traffic where I stop for less than 3 sec it shuts down, but coming to a stop light for over a minute it stays on. I would like it to be then other way around but I'm sure there is a reason.
2015 BMW ///M3 6MT: MW, 19" black wheels, extended leather
Mods: IND back grill, 25% 3M Tint, XPEL Ultimate, V1 concealed display setup, Bavsound S1, K&N+charcoal delete |
08-13-2014, 10:40 AM | #9 |
177
Rep 500
08-13-2014, 10:50 AM | #10 |
Commander-In-Chief
2196
Rep 8,944
Drives: 2023 M2 Coupe, 2020 GLE 450
Auto Stop/Start
If you turn it off it stays off until changed no matter how many starts. Something BMW got right.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
08-13-2014, 11:19 AM | #11 |
Rep 1,282
Yup, works at stop, neutral, foot off the clutch. Cool that you can coast ahead without the motor restarting if you don't press the clutch - a little weird.
Why use this? I was trying to get my MPG over 20, and with the way I'm driving the car during break-in, I need everything I can get to break 20. Finally did it. And yes I"m following factory break-in procedures. Aggressively.
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune Alpina B8, zero performance mods |
08-13-2014, 01:06 PM | #12 |
1255
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
I hate the damn auto start/stop but I might just turn it on if I do some city driving and I wanna max out mpg
08-13-2014, 01:17 PM | #13 | |
BMW Fanatic
374
Rep 1,413
Drives: 2020 X3 M
You can code that crap out btw so when you get your car coded, ask him to change the setting to allow you to stop the car in any conditions.
SteveSpy
Current Ride: 2020 X3 M |
08-15-2014, 02:51 PM | #14 |
Facetious
109
Rep 530
Now I got used to it a bit, and it works most of the time in regular traffic. If its too hot outside, or in stop and go, it usually does not engage. But I like the feature. It is very seamless and I don't understand why people are so negative about it.
08-15-2014, 06:23 PM | #15 |
King Cobra
109
Rep 450
It's also not going to shut off if you are bumping music pretty hard cause those subs suck up a lot of juice. Same with the AC on med-high. Something pretty cool I noticed is when you go to efficiency dynamics in your iDrive it will actually tell you why the car turned back on, or why it can't auto stop.
08-15-2014, 06:28 PM | #16 |
King Cobra
109
Rep 450
I actually find it useful, M car or not. I'm not flooring my M3 every second I drive it. Sometimes I like to put it in efficiency and cruise around light-footed and see what kinda MPG I can get. That's the beauty of a sports car, plenty of power when you want but it's also a good old cruiser too. Just my $0.02 anyways.
08-15-2014, 10:01 PM | #17 |
Commander-In-Chief
2196
Rep 8,944
Auto Stop/Start
I tired it today, and it's good in some situations, like waiting at long lights. The good thing is you can have it on, and if traffic is creeping on and off, you can keep it off by just having the clutch in. I will use it more in the city as I get used to it.
