10-14-2016, 11:32 AM | #45 |
Rep 17
I like your work. Would you be willing to share the CAD files for the custom hexagon led corona.
I have a F30 2013 with halogen. I would like to do the retrofit. The CNC guys I work with can sort out the acrylic for me if I have the CAD model. I understand if you are not comfortable sharing. I live in UK and sending out the headlight to have them moded is not an option |
10-14-2016, 12:49 PM | #46 |
Rep 1,035
Hello ... its been awhile since i've been on these boards. So many other projects have cropped up, that i have so little time now to do anything with the car. For the most part, my F30 is at a place where i want it, and i'm not doing any more mods. In fact, my next big project is starting work on a mercedes for my wife that will be arriving next month.
As far as this work goes, to be quite honest, i've sort of lost interest in doing any more of this, so i will gladly post up any files of the work i've done here so that some enterprising person can take it and continue to do cool custom headlights on this amazing car. I don't have any CAD files per se (e.g. autocad), but i do have SVG vector files that can be printed out using a laser cutter. From there, the pieces have to be heated up and hand assembled. But i have an exact template i can give you so that the pieces can be laid down to form/fashion to the final rings. Would that suffice? |
10-14-2016, 02:06 PM | #47 | |
Rep 17
10-14-2016, 03:21 PM | #48 | |
Rep 1,035
I only have the ring layout template on the computer i'm currently using, and the actual SVG files for the acrylic pieces themselves are at home. I'll have to dig that out later tonight. But you get an idea of how to assemble the pieces together for the final rings. The SVG file has been zipped up. I did the work with Inkscape (freely available/downloadable on Internet), but it can easily be converted to an Illustrator file if your CNC or Laser takes that format instead. Last edited by squidlyboy; 10-14-2016 at 11:48 PM.. |
stxf3094.00 |
10-14-2016, 04:16 PM | #49 |
2221
Rep 5,897
Drives: 2014 335i Black F30 M Sport
Them lights look awesome man!
10-15-2016, 12:05 AM | #50 |
Rep 1,035
Here is the other SVG file (zipped up) as promised. These dimensions are exact and the laser cutter will cut them precisely. The blue lines are for cuts and the red lines are for scoring/etching.
Convert to the color/width as needed to represent cutting and scoring/etching for your particular CNC/Laser. Again, Inkscape or Adobe Illustrator should be able to open this SVG file up, and do conversions to other formats as needed. You will need to cut four of the long sides and four of the short sides to do a full set of (four) rings. You'll also need two each of the bottom pieces for the full set. I only put a single example of each, but you get the idea. i was able to do a full set of rings for about $10-$15 of raw acrylic material Even the OSSdesign 6K Iconic acrylic lenses can be done in the same way for about the same price - the angle bends are just a little different, but it can be heated and bent the exact same way ... don't pay $1500 - what a rip off lol Good luck! |
stxf3094.00 |
10-15-2016, 11:49 PM | #51 | |
Rep 389
Drives: '13 F30 335i MSport
2013 GSM 335i MSport
10-17-2016, 08:36 AM | #52 |
Rep 17
Hi, thanks for uploading the files. The design looks amazing. But I am now thinking of going with the iJDMTOY F30 angel eyes
I don’t know if there is a difference between the US and UK F30 halogen headlights. When I start the car at night I can see some kind of automatic vertical levelling of the light beam. The light beam moves down then up. It seems like the size/depth of the acrylic in your design will block the movement of the bowl. Is this something you simply code OFF? The thickness (less than 1cm I think) of the iJDMTOY angel eyes seems to be just enough to be mounted without restricting the movement of the bowl. |
11-08-2018, 04:06 PM | #54 |
#gotboost
517
Rep 861
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
