05-08-2016, 09:59 PM | #1 |
Rep 1,035
Custom Hexagon Corona Ring Headlights (ala Concept 4 Series / 2016 F30 LCI)
Finally got around to putting on the new headlights on the car a few weeks ago, but wanted to leave them on for a bit before posting up pics, just to make sure they are working great. So far, they've been working like champs.
A summary of the work:
05-09-2016, 07:13 AM | #3 |
1623
Rep 2,036
Yeah...yeah.....great looking and all....
BUT when does your production/assembly line kick in to high gear to crank out a set of these a day??
Chicken_Joe608.00 |
05-09-2016, 01:02 PM | #6 |
100
Rep 443
Every iteration of your headlights keep looking better! Good job man. I totally agree that the lci led with its hockey stick style looks weird towards the inner kink because itd dark and your led lighting throughout the whole acrylic poece makes it look much better. If i werent returning my lease id totally pay you to make me one.
05-09-2016, 06:11 PM | #9 | |
1623
Rep 2,036
Maybe you (squidlyboy) send a résumé to BMW design team?!
05-10-2016, 09:16 AM | #10 | |
Rep 1,035
Hey guys! Thanks for all the cool notes you guys have left! I appreciate them all ...
For the guy who asked about the FEM, i don't touch the FEM at all. In fact, none of the wiring i did messes with any of the OEM wiring. I don't touch OEM wiring in the car _at all_. All the magic happens inside of the new headlight housings, so a simple swap of the stock F30 halogens returns the car to OEM. The power for the lights come directly from the battery post under the hood that goes to a relay (inside the headlights), then the low-beam signal from the car activates the relays, delivering power to the lights from the direct connection. This is the way i did my original quad bi-x lights and I've had that running perfectly any warnings, errors, or issues for about a year now. Quote:
Anyways, i don't want people waiting around if they are in a rush to get some aftermarket lights to replace their F30 halogens. I would go out and get the OnEightyNY LEDs or the Umnitza ones or any number of really cool lights that are starting to proliferate out there. There are a bunch of really nice ones that will make your car look amazingly better than stock halogens. With that said, i purchased enough acrylic to make 8 more sets that i hope to get cut in June as i get access to the laser cutter. So for those who are in no rush, i'll let you know when i get that done... |
05-10-2016, 01:04 PM | #11 | |
e90noob
1589
Rep 1,866
or can you still do it with original xenon housings? i JUST sent money for some f30 empty xenon housings ... talk some numbers with me about your rings with the extended inner bar
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
05-10-2016, 01:16 PM | #12 |
Rep 1,035
i have never dealt with the f30 xenon housings so i can't say for sure. but on top of the xenon housings probably being 3x-4x the cost of simple f30 halogen housings (you can pick up a used pair of halogens for $200-$400), you would have to take the extra effort to dismantle the OEM angel eyes on the xenons to make room for the new angel eyes. Seems like a lot more $$$ and a lot more hassle.
Are you wanting/hoping to re-use the stock bi-xenon HIDs in these lights and just change out the rings? |
05-10-2016, 03:09 PM | #13 | |
e90noob
1589
Rep 1,866
i'm trying to work with what i have instead of going out and buying another set of headlights now i have to decide if i want to source original xenon ballasts ... or go with an aftermarket kit i think i will do this... once i figure out OEM or aftermarket for the HID part, i'll just use the original xenon housings with the original rings for now and wait on your custom rings to be ready and eventually install them into a halogen housing ... or take apart the bi-xenon housing my reasoning is ... if i'm going through the hassle of doing a xenon retrofit into a 2016 LCI sedan, i might as well make it visibly known that i went and put effort into modifying the lights
05-12-2016, 10:30 PM | #18 |
291
Rep 503
so would would be required for us to purchase one of your 8 sets? do we need to buy a set of used halogens and send to you for the retrofit? does the retrofit include projectors and everything? if so I would be IN. and do you have any estimate of cost?
05-13-2016, 02:41 AM | #19 |
Rep 261
05-13-2016, 05:13 PM | #22 |
Rep 1,035
The best way is for me to start with a spare set of halogen headlights (which i currently already have), do the work, then send it to you after you send payment + a security deposit for the headlights. Then after you receive them and install it, you would send me your original halogen headlights. I would then refund you the deposit once i receive your headlights.
With the new set, i would start work on the next one, etc... I'm still working out what i think would be a fair price. I'm not out to gouge anyone, but it is a lot of work, so it would be in line with the going rate. But it definitely won't be more. Ideally, i would like to just produce the rings and have people do a DIY on their own, but i know that most people don't have the time, patience, desire, and/or nerve to do it, so i realize that installs are going to be just a necessary part of this thing. But if some folks were willing to do the work themselves, 1) they would save a bunch of $$$ and 2) i would work with them / provide support to get it done. As far as the other question as to what is included in the work, I know certain people will want certain things - i.e. some will want only the rings installed, others want some HIDs in addition, so as you add more stuff, the cost will go up commensurately. I'm still trying to figure that part out... |
