Akrapovich Drone on 335i N54 AT, suggestions?
04-08-2014, 04:23 PM | #1 |
Rep 216
Hi All,
In hindsight, I should never had attempted this after the droning I experienced with the OEM PE. However, I took the plunge and installed a brand-new Akrapovich Evo SS exhaust system for my 2010 335i N54 with automatic transmission. With only a slight load, around 1600-2100 rpm, the car exhibits a low frequency drone (bass-like) and gets louder the more load you put on the car. It's not deafening, but it's certainly not quiet either. At times, it can cover the music I'm listening to in the cabin. I was wondering if anyone else that has the Akrapovich also noticed this? Before I took the plunge, most reviews indicated that the Akrapovich did not drone, either with a MT or an AT. Suggestions on how to eliminate the drone would be awesome, as I have searched through the internet and people have posted different attempts at eliminating drone from other exhaust systems. I love the sound of the Akra from 2100 rpm and up, but the bass-like drone can get annoying. I have an AR catted DP as well in front of the system. Thanks for any advice (even if you say I should go back to stock)! |
04-08-2014, 04:25 PM | #2 |
Rep 216
I also contacted Akra and they suggested to go back to stock DP's. They mentioned that they cannot guarantee drone-free if the system is not stock. However, I vaguely remembered they came out with their own version of catless DP as well.
There are no exhaust leaks and there's nothing touching the heatshield, etc (not a rattle). |
04-08-2014, 05:06 PM | #3 |
Rep 1,264
you are bound to get some drone in a completely catless system. Trying putting some resonators on to minimize the drone.
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56| -I will look on your treasures, gypsy. Is this understood?- |
04-08-2014, 05:26 PM | #4 |
Rep 161
I had exactly the same problem, massive drone and vibration from 1500-2000rpm, even with stock secondary cats welded in (also have the stock downpipe without cats). The only solution was to weld in the stock pre-muffler of a E90/E91, but be careful it has 60mm inlets and the akrapovic has 65mm. In the end the evolution system was heavily modified, I would not do it again.
By the way: how did you fit the front pipes bracket? Mine didn't fit because the AT has a different dimensions, so I used the stock bracket, which doesn't fit perfectly with the akra 65mm pipes. Last edited by BigHoncho; 04-09-2014 at 03:36 AM.. |
04-08-2014, 06:03 PM | #5 |
142
Rep 2,661
try dynamating the trunk and if the that small compartment bet. the rear seat is vibrating you can mod it or remove the lid. only option really if you don't want mod or change the exhuast
04-08-2014, 06:34 PM | #6 | |
Rep 216
Got it to fit by adjusting the two bolts that mounted the bracket to the transmission. The bolt furthest away from the pipe was adjusted to a higher position and the closer one to a lower position on the mount. That allowed the bracket to be slanted/angled very slightly downwards. I would say there's only about a 1-2 cm clearance from the heat-shield. By "stock pre-muffler" section, which section do you mean? I still have my stock exhaust. I can probably chop the section needed and weld it in. Thanks. |
04-08-2014, 06:35 PM | #7 | |
Rep 216
I'll see if it's still resonating with the rear seats removed. |
04-09-2014, 03:20 AM | #8 | ||
Rep 161
http://bmwfans.info/parts-catalog/E9...enter_muffler/ The E92/E93 has an x-pipe (kind of) and the E90/E91 has an muffler instead, that reduced the drone dramatically. I bought an used E90/E91 muffler and welded it into the Akra Evo pipes... that not how its meant to be, but it works perfectly. -- Here is another picture that shows what I mean: https://dl.dropboxusercontent.com/u/...ust_system.png Last edited by BigHoncho; 04-09-2014 at 03:26 AM.. |
04-09-2014, 12:07 PM | #9 | |
Rep 216
Did you use the full center muffler with pipes or just part of it? Also, the bracket does fit for automatic transmission. I'll take some pictures in a few days when the car is on the lift to show you. |
04-09-2014, 12:13 PM | #10 | |
177
Rep 2,301
1. oem resonator 2. oem secondary cats which double as silencers 3. To some extent--> Oem mufflers Without these two components in the exact same position, and configuration as your oem cat back, you will have serious drone issues.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
04-09-2014, 12:23 PM | #11 | |
Rep 216
So I'm thinking would just 1. OEM resonator as suggested by BigHoncho be enough or do I really need to weld in the secondary cats as well. It almost makes more sense to just put in the OEM pipes and just keep the Akrapovic mufflers at this point. |
04-09-2014, 01:14 PM | #12 |
Guest
Rep n/a
Drives:
Instead of hacking up the stock pieces I'd probably look into installing some Vibrant resonators, or something, instead:
http://www.e90post.com/forums/showpo...1&postcount=44 Either that, or make your own Helmholtz chambers Or as you mentioned, go with the factory "mid-section" and Akropovich mufflers on the end of that. |
04-09-2014, 01:27 PM | #13 |
165
Rep 2,875
Put the OEM exhaust back on is the ONLY way to avoid drone all together. Aftermarket exhausts ALL have drone, no matter how you look at it.
Another way to deal with it is run the rpm a little higher in each gear than you normally would, maybe a couple hundred rpms higher.... Wanting NO drone on a aftermarket exhaust, is nearly impossible. That's just like saying, I want a sports car that can get me 30-35 mpg (aside from Tesla), it isn't likely to happen. More like one, or the other. My .02
'08 AW E90 335i PROcede V5 | BMS DCI | RR DPs | ETS FMIC | FORGE DVs | Stett CP | Vanguard | PSS10 |
04-09-2014, 02:46 PM | #14 |
177
Rep 2,301
Ditto. See my thread for my exhaust set up. The only droneless setup is aftermarket mufflers welded on to the oem catback. It's not just about simply welding in resonators and secondary cats. It's about where they are positioned on the exhaust. The oem resonators move the drone to a different rpm, and the secondary cats, while being relatively free flowing, change the exhaust note, and help muffle the drone.
'07 335I w/ Mods
04-09-2014, 02:59 PM | #15 | |
Rep 161
04-09-2014, 03:08 PM | #16 | |
Rep 161
I have to say, its a shame to cut those akrapovic pipes, but there is no other way to get rid of the drone. Thanks :-) Last edited by BigHoncho; 04-09-2014 at 03:18 PM.. |
04-09-2014, 03:11 PM | #17 | |
177
Rep 2,301
'07 335I w/ Mods
04-09-2014, 03:19 PM | #18 |
Rep 161
However, the cats didn't change much, but the muffler in the middle did.
04-09-2014, 03:50 PM | #19 |
124
Rep 1,503
I have the same issue with my Remus. I avoid it by driving in Sport Mode. It keeps the RPMs higher and the low bass drone is barely noticeable. I think if you go to any aftermarket exhaust, it'll drone.
04-09-2014, 04:57 PM | #20 |
BD_e92
358
Rep 1,748
04-09-2014, 06:16 PM | #21 |
Rep 216
04-09-2014, 06:22 PM | #22 | |
Rep 216
I'm considering three options right now: 1) Try cutting and welding only the center muffler (resonator) section in 2) Add back in the secondary cats in addition to the center muffler 3) Switch the midsection pipes back to my stock pipes The thing was, I had the full evolution system welded when I had it installed because the pipes did not seal well and had exhaust leaks (due to heat expansion) that high temp RTV silicone did not solve. |
