10-27-2018, 02:34 PM | #155 |
Emperor
1614
Rep 2,753
Bought some corner balancing scales, though I haven’t used them for that yet.
I’m a bit disappointed. The truck/semi weight station had told me the car weighted 3071 lbs, but it would seem that was optimistic. 3112 lbs with a 3/4 tank. Pretty sure that means I’m not going to be able to get it under 3000 lbs with a full interior and quiet (stock weight) muffler On the other hand, 52.6% front, 47.4% rear is better than I was expecting! 52.1% front with me in the car. My winter projects will likely get it just under 3100 lbs. Last edited by Obioban; 10-27-2018 at 04:35 PM.. |
Brake_Late1937.50 |
10-27-2018, 04:05 PM | #156 |
175
Rep 450
10-27-2018, 04:37 PM | #157 |
Emperor
1614
Rep 2,753
Brake_Late1937.50 |
10-27-2018, 06:53 PM | #159 |
Emperor
1614
Rep 2,753
Brake_Late1937.50 |
12-27-2018, 08:29 AM | #164 |
Emperor
1614
Rep 2,753
One of my winter projects on the M3 is brake ducting. I made some progress on that recently.
3D printed brake duct I designed. They are not cleaned up at all, because I didn't know if they'll be final. They attach to the factory mount points, and run the air through the center of the factory brake duct/underbody mount bracket, so there won't be any hard bends in the 3" soft line. They don't attach to the factory bumper, which means no unsightly screws visible on the bumper and taking the bumper off isn't a PITA: They do fit with the fog light mount bracket attached.... but it's ugly. Soooo... painful to do, after 15 years of faithful service from this bumper, but time to trim: How it looks with the fog light mounting provisions all trimmed off: Please excuse the Tesla like panel gaps in the bumper. Nothing was clipped in place because it was just a test fit-- still had to install the passenger side. On the rotor side, I'm planning to use the Hard Motorsports 355mm BBK rotor duct, as it's the only solution I know of that's designed to work with 355mm rotors. It also vents into the center of the rotor, instead of the face, which is the correct way to do it (I was talking to one of Brembo's engineers, and his take was the ducting onto the rotor face on one side, but not the other, was worse than no ducting at all). I did make an alternate version of the duct that include an intake air feed for the CSL box, similar in concept to the Evanturi bumper scoop. I'm going to monitor my IATs and install it if they're elevated vs ambient (they weren't before when above ~10mph). If they're not, I'd rather have equal brake ducting for the driver and passenger side. I'm pretty enthused with the "look" of it, installed. That's pretty rare for me-- I almost always hate any change initially. But, I think they look "stock" if you didn't know the e46 m3 came with fogs from the factory. That's my criteria for any mods that change the look of the car-- if someone can pick out any given part as aftermarket, I don't want it on my car.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
CarPoor140.00 E90M3velocity337.50 |
01-03-2019, 10:16 AM | #165 |
Emperor
1614
Rep 2,753
Winter projects underway! The front end is getting a bunch of stuff done. Including, but not limited to...
-ZHP steering rack -fresh inner and outer tie rods -reduced assistance from the power steering pump -new power steering lines and reservoir, converting the system to CHF-11S -CSL Kingpins -new front wheel bearings -new spring rates -going back to the stock oil cooler -the previously mentioned brake ducting -replace all fluids, everywhere in the car I had some time on new years day and started pulling her apart. ^that's copper anti-seize, not rust :lolhit: Lots of original parts getting replaced, which doesn't happen very often anymore
01-03-2019, 02:08 PM | #166 | |
1938
Rep 3,297
That should yield your desired goal area I believe. Not that difficult to do either. We did our own on all of our previous racecar preps. From stock anything to de-deadened is a big jump down in weight...whatever the car. GL OP 🚆✨☄️🔥
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams, CarbonStrucktureAnthracite, CF_Everything BMWPhotoVin, 01of01, GTS DCT, EPS, MDM, CS EDC,Analog Dip ,GTS parts. Euro Vin e30 M3, FIA cage / 14.7 p / w ratio. Euro E30 touring G30 MSport i3s LBB X5M 3.2carrera https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA |
01-03-2019, 02:10 PM | #167 | |
Emperor
1614
Rep 2,753
If I'm stuck in the 30XX lbs range as a result, so be it.
Brake_Late1937.50 |
01-03-2019, 02:11 PM | #168 |
1938
Rep 3,297
Nice I totally hear ya...🏁
That's a great street weight for this chassis Defeat steer
01-12-2019, 08:05 AM | #169 |
Emperor
1614
Rep 2,753
Thought I should update last weekends progress before I started this weekend...
Cooked the studs out of my old hubs (getting replaced with the wheel bearings, as they're part of the same part): Swapped the springs for 325 lb/in driver front, 300 lb/in passenger front, to try out the flat ride thing (still need to change the driver rear for a 700). Amazing how stock the Ohlins look with a black spring (as least if you're used to colors): Swapped in the ZHP/yellow tag/712 steering rack (along with new (OEM) Lemforder inner and outer tie rods: I'm also swapping the reservoir, since the PS fluid filter is built into it. But, I was pleased to see that the new cap is a CHF-11S cap, w which is the fluid I'll be running in this car going forward
Brake_Late1937.50 |
01-29-2019, 05:16 AM | #170 |
Emperor
1614
Rep 2,753
Brand new parts are so satisfying to work with. It's like having a CA car :roll:
CSL kingpins (with anti seize), Hard Motorsports 355mm brake duct backing plates (which are shitty, but I can't find an alternative), and new OEM (***) wheel bearings with OE dust caps. |
Brake_Late1937.50 |
01-29-2019, 08:04 AM | #171 |
1938
Rep 3,297
How do those compare to say Bimmerworlds
https://www.bimmerworld.com/E46-M3-B...6-Z4M-MZ4.html Or even VJs at Achilles backing plates ? https://www.achillesmotorsports.com/...des-s/1945.htm
01-29-2019, 10:00 AM | #172 | |
Emperor
1614
Rep 2,753
Brake_Late1937.50 |
01-29-2019, 11:07 AM | #173 | ||
1938
Rep 3,297
01-29-2019, 12:42 PM | #174 |
Emperor
1614
Rep 2,753
I believe this is the only option on the market made to work with a 355mm BBK.
Brake_Late1937.50 |
02-08-2019, 10:20 AM | #175 |
Emperor
1614
Rep 2,753
I've had a rethink on how I'm going to route it through the undertray.
I'm going to pass it through right below the sway bar mount bracket. But, instead of drilling a 3" hole and sticking the tube through, I'm going to print a bracket. On the far side I'll add some BMW under trim screw clips. The bracket will pass through and insert into another bracket on the other side. Screws will pass through the outside bracket, then through the underbody panel, then into the far side bracket with attached screw clips. This should minimize the hassle for any project where the undertray has to come out, or where I need the ducting out of the wheel well for car work, and make replacement hose easier (and less of it required) if something happens to the hose in the wheel well. Inside bracket: Outside bracket: 3 screws will take everything apart, while leaving the hose clamped onto the bracket
02-22-2019, 11:30 AM | #176 |
Emperor
1614
Rep 2,753
Well, my pass through duct plan didn't work out. The flat portion of the belly tray doesn't extent far enough back to pass it through there and have the duct not interfere with the tire when at full lock. So, I just cut a 3" hole towards the front, and then made it into a U shaped slot that inserts over the duct. Not as fun as what I was hoping for, but it works :P
Anyway... Wheel turned all the way in: Wheel turned all the way out: All the way out, from next to the car: Mounted up from the front: Unless I run into unexpected issues, I think this is complete.
